Any ideas!i've got hope x2s and i'm running 10 speed so i've just one shifter, a shimano slx which makes it awkward to change gear, need a shifter that will come further past the lever.
Posted : 30/12/2011 3:14 pm
Do you mean you can't reach the shifter lever because the brake clamp is too wide? Just swap them over if that's the case.
Posted : 30/12/2011 3:22 pm
Think you can get a spacer to fit to the lever to push it past the brake lever. I am sure someone more resourceful will be along to post you a link 😉
http://www.chainreactioncycles.com/Models.aspx?ModelID=41014
Think those are the ones......
Posted : 30/12/2011 3:28 pm
I run my shifter inboard of the brake lever - problem solved!
Posted : 30/12/2011 3:29 pm
