Does any one else have issues with the spacing or free movement of the right side fork leg on the axle. Once the the axle is tight without the pinch clamps done up I can pull the fork lower back and forth along the axle a few mm which isn't an issue as you can't obviously when the clamps are done up but the wheel rocks side to side between the legs as if the bearings are caput when rocked with hand on tyre and stantion. Bearings are good and I've tried it with other pro 2s. I have a nuke proof to try too but it's at the back of the bike pile at the mo so will dig out at the week end. If I close the gap by pulling the lower in to the wheel by squeezing the lower towards the spokes the wobble goes but I'm sure this isn't right and could wear the stantion un evenly. Its almost as if the 20mm adaptor on the non brake side is too short. Any one else noticed any issues ?
Got Pro 2s and 36s, they're pretty tight even with the clamps open. Maybe try taking the adaptors out and have a quick check.
I had the same issue with some 20mm revs ended up changing bearings still no better swapped it out for different hub and the problem was gone. Never found out what caused it
