Hope pro2 replaceme...
[Closed] Hope pro2 replacement bearing question - HELP A NUMPTY OUT
[#4257173]
My front hub is feeling a bit rough, so I'm going to give it a grease to see it that works.
But if I need to get some replacement bearings are [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=588 ]these[/url] what I need?
Thanks in advance.
Posted : 14/08/2012 11:33 am
The front bearing numbers are 6804 2rs. Just google it and that should point you in the right direction.
Posted : 14/08/2012 12:51 pm
if they are feeling rough adding grease won't help if they have a sealed bearing (it 'should' be sealed) as the grease can't actually get to the race & balls.
Those are signed for a bulb hub, do you have a bulb or a pro2?
or
Edit: I take it back 61804 fit both. (2RS just means 2 rubber seals) HTH
Posted : 14/08/2012 12:54 pm
The bearings in your link appear to be for a Hope Bulb.
I'm not sure whether the Pro 2 are the same or not; I guess CRC will have the correct ones listed as Pro 2 (or speak to your LBS or bearing supplier). Get the original Hope spec ones or good quality replacements.
Use the proper Hope tools or failing that a drift (as I do) to tap out the bearings from the inside and then gently tap in the new ones, having remembered to replace the alloy spacer inbetween the bearings.
In my opinion its a waste of your time to re-grease the bearings if they already feel rough; within weeks they will be rough again or worse.
Posted : 14/08/2012 12:55 pm
As lipseal says, those are the numbers. Try [url= http://www.merlincycles.com/bike-shop/wheels/wheel-accessories/wheel-spares/hope-hub-complete-bearing-kits.html ]Here[/url]
Posted : 14/08/2012 12:56 pm
Posted : 14/08/2012 1:28 pm
That's an extortionate price to pay for some bearings. I bought some much cheaper ones off ebay and they are fine.
Posted : 14/08/2012 2:12 pm
I like kaesae's bearings, on ebay, katec bikes or something.
Posted : 14/08/2012 2:16 pm
I wouldn't discount the like of Hope bearing kits from UKbikestore, they use quality bearing (INA) & seemingly are cheaper than a lot of suppliers for the same thing. I definitely wouldn't be tempted to use cheap unbranded bearing off ebay...
Posted : 14/08/2012 2:22 pm
Thanks for the replies.
I've orders the bearings from Merlin, thanks CaptainMainwaring.
@ OrangeJohn, where did you get your drift? I've got a makeshift press, which a threaded rod with an assortment of large washers on. For removal I was going to use the old 'socket on an extension bar give it a light whack with a rubber mallet method'.
When I've got more time to I'll explore the non hope bearing route - but I'm in bit of a rush this time round.
Posted : 14/08/2012 4:59 pm
