Hope pro2 evo hub a...
[Closed] Hope pro2 evo hub axle sizes help please if you please sir
[#5023931]
Hi hope someone can help i want to change my rear wheel to a 12mm through axle. the inside diameter of the existing axle on the wheel is 12mm but it shows a kit to convert with an axle in it so does this mean my existing axle will do the job or does it need to be changed?
Posted : 02/04/2013 9:31 pm
Just need the 12mm end caps
http://www.chainreactioncycles.com/Models.aspx?ModelID=68578
Posted : 02/04/2013 9:40 pm
cheers wysiwyg 😀
Posted : 02/04/2013 9:43 pm
