Hope pro2 100mm con...
[Closed] Hope pro2 100mm conversion to 135
[#10444054]
Any idea if a p hope pro2 100mm qr be converted to a 135 15mm?
Thanks
Posted : 18/01/2019 8:08 am
135x15 ? You got something a little mixed up here ?
Posted : 18/01/2019 8:10 am
rear wheel steering?
Posted : 18/01/2019 8:26 am
 qtip
For a fat bike innit. Doubt such an adapter exists.
Posted : 18/01/2019 8:32 am
Hmmm,
Well the 135 bit is definitely correct.
https://photos.app.goo.gl/qHBkYfcTaiHx3EnT8
I'll measure the diameter when I can.
It's a Travers prong.
Posted : 18/01/2019 8:34 am
Yep. Definitely 135x15mm.
Posted : 18/01/2019 8:40 am
ah, in that case, i'm right out of ideas, i've never done the fat-bike thing.
Posted : 18/01/2019 8:42 am
 qtip
Actually, there’s this adaptor on eBay: [url] https://www.ebay.co.uk/itm/MTB-Tools-Adapter-Set-For-15mm-x-100mm-Front-Hub-To-15mm-x-135mm-Fat-Bike-Fork/252348997344?hash=item3ac12c1ee0:g:b1gAAOSwGYVXCCCI [/url]
You’d also need a Hope QR to 15mm adaptor though.
Not sure I’d want to be using adaptors like that though, I’d rather spend a bit more and get a proper fat bike hub.
Posted : 18/01/2019 8:43 am
Get a 135mm hub. Especially if you're running 'proper' wide rims.
also, make sure you get the right disk spacing hub for the fork.
Posted : 18/01/2019 8:45 am
It can be done but it isn’t pretty. You need to space the disc out 17.5mm and then run adaptors either side of the hub. I had a set on my Jones for a dynamo and it didn’t work as a dynamo. The tolerances need to be exact.
However, this was a temporary solution for a race. My regular 135mm wheels are much stiffer as they’re wider at the hub, and this means they’re dishless.
Posted : 18/01/2019 9:17 am
thx all.
There was a bargain on offer so thought I'd check but agree with the above & I declined the 'bargain'.
Posted : 19/01/2019 10:21 am
