Hope Pro 4 Freehub ...
[Closed] Hope Pro 4 Freehub Help
[#9909156]
Hi All
Can anyone help me identify the Hope Pro 4 freehub in the picture (hopefully) linked below?
https://1drv.ms/u/s!Anja8-bC2nmqhbcvKbQEymNlk0tb2g
The wheel was bought off ebay and was stated to have a Shimano freehub, however it's too small to fit my 10sp cassette. I'd just like to know what it is before I contact the seller.
Thanks
Posted : 24/03/2018 4:45 pm
Isn't that the special.driver for the hope cassette?
Posted : 24/03/2018 5:21 pm
Yes, that's the Hope Cassette driver installed, the Shimano body is gold with green seal.
Posted : 24/03/2018 5:26 pm
Cheers guys, I've messaged the seller so I'll see what they say.
The next problem is that I've mounted the wheel into the frame and I'm now finding the the IS adapter for the rear brake is binding on the disc when everything is tightened up. It was fine with the old wheel.
Any suggestions whet might be causing this? Pic below.
https://1drv.ms/u/s!Anja8-bC2nmqhbcwJRebWRRJNFA5-g
Posted : 24/03/2018 5:35 pm
I'll give you a tenner for it...
Posted : 24/03/2018 5:54 pm
Ha, which bit?
Posted : 24/03/2018 6:24 pm
Could be the wrong adapter for your frame, a 142 instead of a 148 or a 135 instead of a 142?  Done that when replacing a wheel.
Posted : 24/03/2018 6:53 pm
@Milky
I suspected that at first, but I checked and it's definitely a boost axle.
The Hope cassette specific freehub seems to come with a different drive side axle endcap. Could that be causing a problem?
Posted : 24/03/2018 7:47 pm
