Hope Pro 2 Evo &...
[Closed] Hope Pro 2 Evo & Pro 4 - Same width?
[#11880357]
Picked up a used rear wheel to replace a goosed Pro 2 Evo.
Old one is none boost 142x12 and the replacement Pro 4 is supposed to be the same.
Had hoped it would have been a straight swop but the new wheel isn't as wide, some 5mm narrower.
Quick google shows the 142/12 adaptors are the same on both hubs.
Annoyingly the adaptors on the old pro 2 evo are stuck.
Are both hubs the same width? Am i missing any parts in addition to the adaptors.
The seller removed an XD freehub for a standard Shimano, could that be it, XD requires a different adaptor?
Going to drop off at LBS to help get adaptors off.
Excuse the rambling, a 2 minute job has dragged on a bit.
Posted : 13/05/2021 11:08 am
Do we still need to do the double post thingy?
Posted : 13/05/2021 11:09 am
I think the xD freehub had a different end cap, if I remember rightly. Otherwise shound be interchangeable
Posted : 13/05/2021 11:13 am
Sounds like the Pro4 hub could have 135mm x 12mm adapters fitted.
Try using a pair of pliers with the ends covered in a rag to remove the adaptors from your Pro2 Evo hub.
Posted : 13/05/2021 11:21 am
Cheers guys, will persevere and swop adaptors.
Tried pliers yesterday and lent my vice to a buddy, hence LBS.
Fingers crossed will come back all happy.
Posted : 13/05/2021 11:26 am
https://uniortools.com/eng/product/1758-4-hub-genie
This would help with the end caps.
Posted : 13/05/2021 11:52 am
My understanding is that Pro 2 have two type of end caps, depending if you need Shimano HG or Sram XD freehubs, where-as Pro4 only have one type of end cap for both HG and XD. Good shout on the 135mm end caps currently being fitted
Posted : 13/05/2021 12:29 pm
There's also confusingly 2 versions of the pro2 evo with different ratchet rings and hub bodies, only the latter one will accept a 12s cassette (or 11s road).
Posted : 13/05/2021 12:34 pm
They are called "Pro 2 Evo" and "Pro 2 Evo 40t". The latter has 40t marked on the hub shell and I think uses the same freehub as the pro 4.
@Z1ppy I thought the HG, microspline and XD all had their own specific drive side end cap (as does the hope cassette freehub).
Posted : 13/05/2021 1:23 pm
 igm
Cheaper than the Unior solution (assuming 12mm thru axles)
https://www.toolstation.com/fischer-nylon-sx-high-performance-plug/p92105
You will need the right size of screw too I suppose.
Posted : 13/05/2021 2:47 pm
Neat trick @igm
Posted : 13/05/2021 2:54 pm
I don't think that is correct. Sure the pro 2 and pro 2 40 tooth use the same freehub. The pro 4 is a bigger diameter.
Posted : 13/05/2021 3:30 pm
No The pro 2 evo 40t version supports 11 speed road cassettes. The pro 2 and pro 2 evo do not. The evo freehub will not fit the pro2 as the axle/bearing size changed. The drive side flange moved on the pro 2 evo 40t.
https://conseilvelo.wordpress.com/2015/11/03/hope-hub-and-body-cassette-11-speed-compatible/
Posted : 13/05/2021 3:36 pm
Huzah! Old adaptors have fixed the issue, expect was 135 adaptor on the old wheel.
Cheers one and all.
Posted : 14/05/2021 10:16 am
