hope pro 2 evo hub...
[Closed] hope pro 2 evo hub and 1x11
[#8088169]
looking at going to 1x11 from 3x9 but the hope site suggests my hub i not compatible with shimano 11speed..find this odd as most places say 11sp cassette is the same as size as 9 and 10 speed..
http://www.hopetech.com/11-speed-compatibility/# my hubs are the blue one with the red X next to it.
other question is if i go Sram xd free hub body will that make it compatible..this may be batter as i think the gear ratios are better with Sram cassettes
rear is 142x12 if that helps..
ta
Posted : 03/10/2016 12:38 pm
Remove current freehub, fit xd Freehub. That's it. Same as swapping freehub s normally. Running gx here hard wearing and like the range
Posted : 03/10/2016 12:39 pm
 momo
That compatibility chart is referring to road cassettes where 11s is wider than 10s. MTB cassettes are the same width from 8-11s. the largest sprocket is dished over the spokes for clearance. I'm running a Shimano 11-42 m8000 XT cassette on an early ProII evo (pre-40t) also 142x12 axle.
XD is required if you want to go SRAM, and it's what I'll be doing when I wear my cassette out, better range and less weight, not much price difference now either as Shimano have gone up in price while GX cassettes are available for £85ish now (was £110+ when I first converted to 11s)
Posted : 03/10/2016 12:46 pm
hi mike so is your hub the same as mine then..cant understand how a sram body is narrower than a shimano one to make it fit
im confused by the hope article im unsure if its saying mtb 11sp is compatible but rd 11sp isnt..arggh man ffs
Posted : 03/10/2016 12:47 pm
thanks momo read it again and the penny has dropped... 😳
Posted : 03/10/2016 12:49 pm
I have 11 speed shimano cassette on a pro 2 evo hub.
It just works.
HTH
Lugz
Posted : 03/10/2016 12:50 pm
Pro. 2 evo 142x12
9/10/11 speed shimano are all exactly the same. Road is different.
XD and sram 11 is also different as the 10t is narrower than the standard freehub body.
Posted : 03/10/2016 12:51 pm
thanks so which xd body and end cap will i need if i prefer the sram range will i need
Posted : 03/10/2016 12:55 pm
Depends on the axle. Quickest and simplest way is to wander into a nice bike shop and they will order and fit you one.
Posted : 03/10/2016 12:57 pm
thats the problem ny local shops arnt great..asked them at the weekend about this..reply was dont know anyway 1x11 is pointless... 🙄
Posted : 03/10/2016 1:03 pm
http://www.hopetech.com/product-documents/
Drop a mail to hope with the stuff you have
Posted : 03/10/2016 1:06 pm
when you order the XD freehub you can choose which end cap you want.
Posted : 03/10/2016 1:40 pm
