Hope pro 11 freehub...
[Closed] Hope pro 11 freehub lube?
[#2532170]
Right , I followed the hope tech video, remove freehub to clean it up and relube. they say smear a small amount of grease around the serrated inner of the hub, which i did . Popped the freehub back on and when the wheel spins there's only a faint clicky noise from the freehub instead of the usual pronouced clicks. It works perfectly fine other than that.
Is there a specfic type of grease for this? i just used the stuff i had to hand or will the crisp sound return as the grease wears in?
Posted : 05/03/2011 4:48 pm
As long as you haven't overfilled the space, the pawls will push excess grease away over time. I use Rock n Roll Super Slick as it's relatively light but is tenacious enough to stick to everything it needs to stick to.
Posted : 05/03/2011 4:54 pm
Thats normal, serviced both of mine many times, they are always quieter after greasing, they will slowly get a bit noisier with time. FWIW I use a light semi fluid grease, which never comes out of the hub seal, and keeps the hub innards well lubed and quiet(ish)
Posted : 05/03/2011 5:45 pm
something not too sticky is great, click will return.
Posted : 05/03/2011 6:24 pm
