Hope Picknmix heads...
[Closed] Hope Picknmix headset problem
[#7471010]
Just bought a s/h frame with headset fitted and I can't get the top cover to sit flush on the bearing because the taper ring sits about 2.5mm proud. Either the taper ring is the wrong one or the bearing has the incorrect bevel - it seems to be in the correct way up.
Anyone have any idea of the problem based on the pics?
[img] http://i809.photobucket.com/albums/zz12/hthecat/P1070182_zpsotkxo2nw.jpg [/img][img] http://i809.photobucket.com/albums/zz12/hthecat/P1070179_zpshtd4vdrq.jpg [/img][img] http://i809.photobucket.com/albums/zz12/hthecat/P1070172_zpslljvtnu4.jp g" target="_blank">http://i809.photobucket.com/albums/zz12/hthecat/P1070182_zpsotkxo2nw.jpg [/img][img] http://i809.photobucket.com/albums/zz12/hthecat/P1070179_zpshtd4vdrq.jpg [/img][img] http://i809.photobucket.com/albums/zz12/hthecat/P1070172_zpslljvtnu4.jp g"/> [/img]
Posted : 22/11/2015 11:46 am
looks wrong that does
Posted : 22/11/2015 11:51 am
Don't think it is right
Posted : 22/11/2015 11:56 am
the conical washer looks too big for a hope
Posted : 22/11/2015 12:02 pm
As above thats not the correct Conical washer. Hope ones usually have a Parallel section then the taper.
Either that one hasnt been machined correctly or its not for that headset
Posted : 22/11/2015 12:11 pm
Thanks Sam - I'll check that out further.
Posted : 22/11/2015 3:03 pm
