Hope Matchmakers
[Closed] Hope Matchmakers
[#3285223]
Does anybody know if the Hope Matchmakers fit the older style Mono M4's (the Black and Gold ones)?
Posted : 26/10/2011 8:42 pm
Nope, they won't. As far as I know they fit the newer Tech type levers.
Although I could be wrong.....
Posted : 26/10/2011 8:57 pm
If the split clamp is the same dimensions then yes...I'd say so.
Posted : 26/10/2011 8:58 pm
Officially no. The tech clamp is at the back of the bar where the old mono levers was under the bar. Shifter would be 90deg out of position. However there are different matchmakers for the race x2 brakes which i think have the clamp in the same position as the mono mini. If the hole spacing is the same or vefy close on the clamp these may fit. Have been thinking of ordering some from crc and trying it, if they don't fit then you can return the order.
Thanks folks
Posted : 26/10/2011 11:12 pm
