Hope Match,aker for...
[Closed] Hope Match,aker for Tech 2 lever to XT 11 sp shifter
[#7586022]
Anyone know if I can get a matchmaker for a Tech 2 lever to either the I-Spec II or I-Spec B versions of the new XT shifter?
I'm thinking the existing Tech 2/i-Spec one should work with the I-Spec B, but can't be sure from the tech docs.
(Have emailed them, but obviously don't want to deny someone the opportunity to recommend that I use something else entirely)
Posted : 18/01/2016 1:53 pm
Hi, I asked hope this same question re M8000 Ispec 11 shifter onto the 2 Evo levers. They said they dont do anything for the "old" levers.
Posted : 18/01/2016 3:13 pm
Yeah, I don't expect I-Spec II will work, but I-Spec B is close enough to the ols I-Spec A that it should work.....
Posted : 18/01/2016 3:17 pm
This is the XT I-Spec B 11 speed shifter - looks to me like it would work OK
Posted : 18/01/2016 7:24 pm
I fitted my I spec 2 shifter with x2 brakes using the lockring off a lock on grip. Works great and cost nothing
Posted : 19/01/2016 12:46 am
@naff. Could you show me a pic of this so I can give it a go? I can't work out how you would do that..
Posted : 19/01/2016 7:59 am
