Hope hub end caps …...
[Closed] Hope hub end caps ….. can I ……
[#12150683]
Use the 12mm end caps off of my boost Pro4 hub on my “std” spaced Pro 2 EVO to make it a 142mm hub?
Posted : 13/12/2021 10:29 pm
I think so.
The difference is in the hub shell. Pro2 Evo and Pro4 are the same outer diameter axle. Won't on older Pro2, though.
Posted : 13/12/2021 10:56 pm
From the Hope exploded diagrams for both hubs they are the same.
HUB471 drive side and HUB463N non-drive side
Posted : 13/12/2021 11:15 pm
Actually scratch that, for the PRO2 EVO it looks like the non-drive side is the same, but Hope give different part numbers for the drive side cap, it's HUB462.
Sorry I initially checked for PRO4 Vs PRO4 boost
Posted : 13/12/2021 11:21 pm
I’m pretty sure the 2Evo and 4 have interchangeable end caps. Certainly I’ve been treating them as such but I guess I could have got lucky. Wishiwascalledsteve, are those different part numbers something like microspline vs normal?
Posted : 13/12/2021 11:23 pm
No just the standard Shimano freehub, assume the PRO2 EVO freehub has a slightly different internal profile to the PRO4 (exploded diagrams give different part numbers for the 2EVO and 4 freehubs)
Posted : 13/12/2021 11:30 pm
Linky
They’re definitely sold as interchangeable, or at the very least backward compatible. Running change perhaps?
Posted : 13/12/2021 11:53 pm
In my fuzzy memory, the only spacers that I've found weren't interchangeable are the Sram XD driveside ones. I remember having to turn one down on the lathe to clear the cassette. For Shimano you should be fine.
Posted : 14/12/2021 9:57 am
Yeah, if the freehubs are same type, it should work, but XD has a different cap
Posted : 14/12/2021 10:02 am
