Probably a numpty question this but..
I've just received my new front wheel. I'm changing it 20mm and found that there are two circlips in the bag with the adapters and spokes. Are these to retain the 20mm adapters?
I can't see what else they'd be for but I'd just like confirmation (or otherwise)
Posted : 06/02/2009 1:04 pm
yes, they hold the 20mm spacers onto the hub. They just push into a narrow slot with a screwdriver
Posted : 06/02/2009 1:22 pm
Thank you...
Posted : 06/02/2009 1:37 pm
Just a note: the 20mm spacers will wobble a bit once fitted. It's a bit disconcerting if you've not fitted them before. They're fine once the wheel is on the bike.
Posted : 06/02/2009 2:21 pm
