Hope freehub conver...
[Closed] Hope freehub conversion to singlespeed?
[#10050069]
I have a hope pro4 hub in the rear, with a new possible frame purchase with a pinion gearbox i would need to convert the hub to singlespeed. Is this possible? or new hub / wheel time.
Thanks in advance
Posted : 20/06/2018 11:04 am
Shimano freehub?  Just stick a single speed kit on (spacers and single sprocket)
You can buy a single speed hub if you want but it isn't necessary.
What is the potential pinion frame?
Posted : 20/06/2018 11:09 am
You can buy a single speed hub if you want but it isn’t necessary.
That. The benefit of a single speed specific hub is the flanges are slightly wider spaced. You may or may not notice the difference in riding it.
if it’s the same frame as I’m wanting (IIRC it is...), I’m super jealous...
Posted : 20/06/2018 11:14 am
Its a deviate guide, when you say shimano freehub i take it you mean just replace the hope one? I was hoping to avoid that for now tbf. If i can convert the hope one i will as it saves a wheel rebuild as well.
Posted : 20/06/2018 11:15 am
Shimanos standard. What cassette did you have on before?
you lucky devil you...
Posted : 20/06/2018 11:16 am
Yea, test ride on friday will make my mind up finally. Will take a few months to get the funds together but evrything is pointing in the right direction 🙂
Righto excuse my ignorance, this shimano freehub can be used with hope pro4 hubs?? if so i am one happy man. I have an xd driver fitted currently
Posted : 20/06/2018 11:18 am
Yes, they sure can !
Hope Pro4's can take XD, Shimano or the new Hope propriotry freehub.
Posted : 20/06/2018 11:22 am
I had a ride last month, took 10 mins to convince me to buy! Then the chap buying my flat pulled out at the last minute 😡😡😡
Basically if you don’t run a sram XD cassette, your current freehub will be fine
You can also get a singlespeed kit for the XD freehubs.
See Guesset HERE.
Posted : 20/06/2018 11:24 am
The spline arrangement on the outside of Shimano freehubs is a standard. If you've a Hope hub with a Hope XD freehub then you'll need to buy a Hope "Shimano" freehub or find a singlespeed cog that fits the XD.
Ah! Didn’t know about XD conversion kits!
Posted : 20/06/2018 11:25 am
Ah great news, (not for you tom unfortunately) ill talk to my LBS about what to order to get this to work.
Much appreciated guys.
Quick edit, just saw that conversion kit. 🙂
Posted : 20/06/2018 11:27 am
I hadn't seed the XD kits either.  Looks ideal for the OP unless he wants to go all out and get a new single speed hub
Posted : 20/06/2018 11:30 am
There's a few of the XD SS kits on the market now, though they all offer limited cog options..
I've got a design somewhere that adds a short length of Shimano spline freehub to an XD freehub, to allow you to run a series of spacers for the perfect chainline as well as pick any traditional SS cog. Was faily cost effective too..
Another option is swapping the XD freehub with Shimano with someone on the forum. They are both in high demand due to swappinng for preffered drivetrains (or for the traditional SS setup in some cases).
Posted : 20/06/2018 11:32 am
 Bez
Hope freehubs have an aluminium body, don't they? If so, be sure to get a wide-base sprocket, not a pressed steel one. If not, ignore me. (Though a wide sprocket is still a good choice.)
Posted : 20/06/2018 11:33 am
Actually, before you buy anything check what size sprocket you need on the back and make sure you can get the right size.  Deviate are probably the best people to advise.
Love the look of the Guide, Cranked Mag had one on their stand at the Bike Show.  I'd love a go on one.
Posted : 20/06/2018 11:36 am
Just picking up on the limited cog options thing. The deviate needs to have a 30t rear sprocket to match the front, something to bear in mind if you have a sram freehub currently
Posted : 20/06/2018 11:37 am
If it does need a 30t I think your best bet may be to get/swap for a Hope Shimano freehub and buy a pinion chainring carrier to go on it.  104bcd 30t chainrings are relatively cheap.  When you get your demo take a look at what Deviate are using.
Posted : 20/06/2018 12:02 pm
Guys, great advice all round. Much appreciated
Posted : 20/06/2018 12:08 pm
Just thought of something else.  Freehub pickup.  The Pinion gearbox has a built in freewheel which along with the pickup from your freehub adds to the lag in getting drive when you start pedaling.  If this bothers you single speed hubs generally have more engagement points and reduce this lag.  It doesn't bother me with Hope's 40t freehub but I started to notice with the earlier (were they 24t?) freehubs.
I wouldn't fret about it now but maybe give it a moments consideration on your test ride.
Posted : 20/06/2018 12:12 pm
Deviate supply their own sprocket/chainring iirc
if you get another freehub following rubber bucaneer's advice (which sounds good to me), go shimano and get a spacer kit with more adjustment eg
http://www.velosolo.co.uk/shopsingle.html
looks like that gusset XD kit doesn't give you much choice about where the sprocket sits, which might mean you have to mess around at the other end to try and get a nice, straight, efficient, quiet chain.
Posted : 20/06/2018 12:40 pm
and just one more question, your current hub isn't boost is it?
Posted : 20/06/2018 12:54 pm
Hope (heh) not, the guide is 135x12...
Posted : 20/06/2018 12:55 pm
If you are interested in a swap then i have a shimano freehub on my Hope hub that i'd change for a SRAM driver. Drop me a pm if so.
Posted : 20/06/2018 4:52 pm
