hope disc change
[Closed] hope disc change
[#8406036]
Hi all...
Am in process of replacing my xt discs to hope. Will be using the same size of 180mm front and rear and am keeping the xt caliper .....Question is, is it a straight swap or will there be problems....any advice will be helpful before i order them.
regards
Martin
Posted : 19/03/2017 10:24 am
Whatever brakes do you have?
Posted : 19/03/2017 10:31 am
Should be a straight swap, maybe a little realigning of the calipers
Posted : 19/03/2017 10:34 am
I have had to file down the adaptors to fit hope floating rotors in the past, the rivets can catch
Posted : 19/03/2017 10:36 am
Reason I ask is as above if you don't have hope brakes i wouldn't bother, rivets often catch on other adaptors and callipers.
Posted : 19/03/2017 10:43 am
Which Hope discs are you going for?
The Sawtooth Floating disc rivets can catch some calipers and adaptors, the newer design full of small holes has the rivets much closer to the centre so clears. The standard solid ones are just a fancy disc.
Posted : 19/03/2017 10:53 am
