Hope brakes - help ...
[Closed] Hope brakes - help please
[#10949055]
Should hopefully be a quick one, I am sure I must be doing something stupid but can't see it thus far.
I have a 180mm hope floating disc, and a fox 34 fork with a H adaptor (in theory for a 183 disc) yet the bobbin on the rotor holding the floating part of the disk to the mount contact my pads on my V2 caliper.
Anyone else have this combo and have no issues or worked around the problem? (I could just remove the material from the pads or shim the caliper but both are pretty ugly fixes)
cheers
Neil
Posted : 06/12/2019 12:49 pm
V2 use a deeper brake track so there is a specific V2 rotor. Is this the rotor you have?
Posted : 06/12/2019 12:54 pm
probably not... must indeed be the issue. cheers
Posted : 06/12/2019 12:56 pm
