Hope bb92 creaking ...
[Closed] Hope bb92 creaking help!!
[#10750376]
Hi
So my Pivot mach 4 came with a press fit BB (alarm bells rang but thought it was a bargain so sod it) it was also a Hope so again thought let's do it now 3 hours in and it's started making a creaking noise.
I've always stayed away from a press fit BB so I know nothing has anyone else fixed this problem? Is there an adapter to press in that means you can run a standard threaded BB? I only ask as I have an adapter on my Cannondale bb30 and I run threaded
Any advice warmly welcome
Thanks
Posted : 04/08/2019 10:20 am
What cranks? If they're 24mm, then it's a screw type bottom bracket and tightening it up might sort it. If it's 30mm then the bottom bracket is just bearings and disposable machined cups/spacers.
Posted : 04/08/2019 2:51 pm
You can have press-fit bbs for 24mm crank axles (known as BB92). Which I think is what the Pivot has.
It is said that (re-)installing the bearings with some bearing cement helps, but I haven't tried that.
You can also replace the press-in cups with a metal screw-together arrangement into which bearings are pushed just like with screw-in cups. Wheels Mfg, Hope and others make them. I have the Wheels one on my Slash and it works OK. I still get slight creakage but that is because I am running GXP cranks, in which the left hand end of the axle is prone to creak inside the bearing on account of the design not being so clever.
Posted : 04/08/2019 4:42 pm
It's a 24mm as I'm running an XT crank strangely enough since posting this the creak has disappeared??
Posted : 05/08/2019 10:09 pm
How wet was your last ride? I’ve had water and mud cure all kinds of creaks! 😁
Posted : 05/08/2019 10:47 pm
Can be worth popping things out and giving everything a clean before reinstalling it properly. If as I read it you have the hope thread together version, is it possible it’s worked ever so slightly loose? My OHs pivot has been a lot better since I fitted a wheels manufacturing thread together bb, but it still needs tweaking maybe once a year if it starts to creak.
Posted : 05/08/2019 11:01 pm
Funnily enough slackalice it was a pretty wet ride think I will leave it if the creak comes back I will take the sound advice of swanny, thanks all
Posted : 06/08/2019 5:07 pm
