Hope and Goodridge ...
[Closed] Hope and Goodridge Braided hose washers - oooops
[#2424276]
So, just stripped down a set of mono minis and taken off the banjo fitting, cant now remember which washer goes where, there is one rubber 'o' ring and a copper washer.
I'm thinking, rubber o ring between caliper and underside of banjo, copper washer top of banjo under banjo union bolt ?
Anyone - before I put it back together and swear when it leaks !
Thanks
Posted : 01/02/2011 12:29 am
Posted : 01/02/2011 12:46 am
Sorry, I missed the 'mono' bit. Obviously your caliper doesn't come apart.
Posted : 01/02/2011 12:54 am
There should be a groove for the o ring to sit in. Nine appear not to have copper washers.
Posted : 01/02/2011 1:01 am
 jeff
Long time since I've done this, but I thought that the banjo had rubber o-rings on both sides, with the special bolt going directly onto them. the copper washer goes on the lever end (though I ran a set of minis without these washers with no leaks...)
Posted : 01/02/2011 1:06 am
Odd, mine had copper washers both sides of banjo with no o rings of any type.
Posted : 01/02/2011 1:14 am
For banjo bolts on hope, it's washes, for banjo bolts on goodridge, it's o-rings. Both use washes for the inline connection. Which brand of hose do you have? If there's any o-rings, I guess goodridge. As said above, there is a recess on both sides of the banjo.
Posted : 01/02/2011 7:46 am
Hoses and fittings are goodridge on hope mono mini levers and calipers.
Posted : 01/02/2011 4:08 pm
