Hollowtech BB beari...
[Closed] Hollowtech BB bearings that dont need the black plastic top hat spacer?
 diz
[#473010]
Does anyone know if a replacment bearing is available that dont need the black plastic top hat spacer? As fitted as standard to Shimano Ht 2 bottom brackets.
Posted : 15/04/2009 8:52 am
Not sure going without the spacer (assuming correct internal dia on the bearing) is a good idea. More likely to cause damage to the axle of the crankset if bearing goes.
(Sorry i know i havent helped answer your Q)
Posted : 15/04/2009 8:54 am
[url= http://www.enduroforkseals.com/ ]these ones don't[/url] but I think bigyinn has a point
(on the other hand, I suppose the bearings will be bigger so may not be so poor in 1st place)
Posted : 15/04/2009 9:08 am
 Del
how long after they're knackered are you going to leave them on the bike, or are you not going to fit them with any grease?
Posted : 15/04/2009 9:12 am
There is a good reason why all crank manufacturers use a nylon bush, the only people who dont - dont make cranks.... says something dowesnt it about the thought gone into them
Posted : 15/04/2009 9:34 am
