hollow crank extrac...
[Closed] hollow crank extraction /numpty question
[#7225226]
Got a specialized rockhopper m4 yesterday ,need to remove cranks as chainwheel side pedal threads crossed.
Hollow axle ???
so conventional extractor no good.
which tool do i need ?
Posted : 29/07/2015 10:42 am
If it's an ISIS/Octalink BB you just need to put a 5p across the hole and use the standard connector (or get an ISIS compatible tool).
I've assumed it's a conventional axle BB.
Posted : 29/07/2015 10:43 am
Conventional in octalink ,yes n hollow axle .
will have to use a 5 cent as in eire,are they as strong as 5p .?
Thanks will give a go .
Posted : 29/07/2015 10:46 am
use two 🙂
as long as they fit down the threaded part of the crank arm and rest securely on the outside of the axle you should be fine.
Posted : 29/07/2015 10:47 am
Success after trying combination of 1 cent pieces ,they do bend nicely around end of extractor,now got nice copper end molded around it now ,looks quite cool 🙂
needless to say it was reluctant to to be extracted.
may look at different BB now with new crankset,time to search e-bay
Posted : 29/07/2015 11:17 am
