High volume shock o...
[Closed] High volume shock on regressive rate suspension?
[#1384504]
Looking at replacing my float r on my prophet and wanted to know if high volume shocks are suitable. Does the high volume lend them to easy bottoming out?
Posted : 05/03/2010 10:26 am
A high volume shock will not be as progressive as one with a standard can so yes, it will go through the end of the stroke faster/easier.
Posted : 05/03/2010 10:28 am
as the it has a regressive rate rear suspension design, & the HV shock with it linear action, means that their not well suited to each other (it'd bottom out easier).
I'd get your Float R tuned
Posted : 05/03/2010 12:07 pm
it will still be progressive, just not as much. I'd stick with what the manufacturer chose.
Is the prophet actualy regressive or aproximately linear?
Posted : 05/03/2010 12:10 pm
pfft I dunno I just read someone say it and someone say it about the heckler too. If it's linear I might get the high volume one as this float is about as plush as a girder.
Posted : 05/03/2010 2:01 pm
The Prophet's regressive rate is designed with a low volume shock in mind so that the natural progression of the air shock works out as a linear rate on the bike. A high volume shock will just plunge through the travel in a less controlled way. If you can afford it, get a 2010 RP23 with the boost valve. Works superbly on my Prophet.
Posted : 05/03/2010 3:28 pm
Consider getting the propedal tune changed on the float. Mine was like a completely different shock afterwards.
Posted : 05/03/2010 3:34 pm
The prophet is definitely a falling /regressive rate frame design, so a high volume shock would be a bad idea - you'd almost certainly end up with a falling rate overall, which is rubbish (poor small bump sensitivity and easy bottoming).
I add extra oil to the air chamber on my standard size rp3 in order to reduce the volume a touch further and thus make the shock more progressive. This is to counter the falling rate design of my C'dale rush (which is very similar to the prophet).
Posted : 05/03/2010 4:08 pm
