High roller for the...
[Closed] High roller for the front
[#3576618]
XC use, on my anthem. What compound do I go for?
can someone send me a link for the right one to go for.
Posted : 17/01/2012 7:47 pm
42A dual ply.
HTH
Posted : 17/01/2012 7:48 pm
Is 42A not a soft compound version surely and will drag a lot for an anthem?
I'd go 60A, front or rear.
Posted : 17/01/2012 8:09 pm
wheelie
Posted : 17/01/2012 8:10 pm
 Euro
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=5845 ][b]Top[/b] [/url]one if you're feeling flush, middle one if not, bottom one if you're happy to have to pedal a bit more in exchange for more grip.
Only fatties with no bike handling skills should consider the dual ply as it's a bit ott for cross country.
Posted : 17/01/2012 8:14 pm
i'd choose a different tyre.
I run a 60a on one of my bikes and find it hard work for traditional 'style' XC. Good on rocky stuff, peak district, trail centre stuff though.
Posted : 17/01/2012 8:15 pm
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=5845 ]Here[/url] is a generic link. **edit - too slow!**
A nice 60a will be more than enough. I generally use a set of 60a wire hihgrollers all year round. The 42a is only worth it for really slippery work (i have 42a swampthings for when it's really slippery)
Posted : 17/01/2012 8:19 pm
Better off with Maxxis Advantage
Posted : 17/01/2012 8:23 pm
I'd go for single ply. Less weight to push and you're less likely to suffer from pinch flats if you mainly ride XC. I ride AM and use single ply on the front and never had a problem with sidewall associated problems. 😀
Posted : 17/01/2012 8:39 pm
skywalker - Member
Skywalker has a point too
Posted : 17/01/2012 8:40 pm
Depends [i]entirely[/i] on what you want to do with it, what your idea of XC is. Some folks would fit a supertacky and justify it, others will fit a maxxpro and still not use all the grip, and end up dragging around more tyre and more weight/drag than they need. So in conclusion, no idea.
Posted : 17/01/2012 8:42 pm
I agree with Brant the 42a dual ply is all I will use for my XC race bike.
If you need anything less than the 42 you arnt going round the corners fast enough.
Posted : 17/01/2012 9:10 pm
 IanW
2.35 60a exception, look and ride perfect on an Anthem . They turn it into a trail bike like they do any bike.
Posted : 17/01/2012 9:11 pm
I use a super tacky, single ply on the front for my idea of XC and its fine. I run a 60a on the back or a semi slick when the sun comes out.
I used to rave about Minions n my DH when I leaved in the peaks, but I've gone off them for some reasons since moving south; I swore by them riding in Wharncliffe, but at Stile Cop I feel out of love very quickly. Strange.
Posted : 17/01/2012 9:32 pm
Does the advantage have less rolling resistance than the high roller?
I have crossmarks on at the moment. Just want more grip on the front in the corners.
Posted : 17/01/2012 10:26 pm
I run a 2.35 60a Kevlar bead high roller on the front and a 2.35 60a Kevlar minion front on the rear for winter trail use on my BFe. I find it a great combo with plenty of confidence but not too much drag on the uphill.
I've also got the 2.35 wire 42a singleply high rollers but I find them a bit to draggy for the kind of riding I do so I only used them a couple of times last winter.
If you are up Edinburgh way I'd sell you a 42a high roller for the front for a tenner as I've got a pair but only use one up front in the worst of conditions.
Posted : 18/01/2012 12:20 am
