Help; worn xt crank...
[Closed] Help; worn xt crank axle
[#3805002]
Ive recently bought a second hand bike which came with an xt crankset (m760). The crank arms had a wobble so I removed the bottom bracket which was badly worn, on inspection of the crank's axle there is a groove worn in at the non drive side end (roughly near where the bottom bracket cups would be). Is it worth me getting a new bottom bracket for them or once the axles get worn around that area are they completeley shot?
Posted : 24/03/2012 3:50 pm
I remember buying a second hand one with the same problem. I built the groove back up again with araldite but I never really got it perfect.
Posted : 24/03/2012 5:13 pm
anyone else had similar problems?
Posted : 26/06/2012 10:59 pm
I'm afraid it's dee..ee..deed... Sorry.. 😥
Posted : 26/06/2012 11:02 pm
Gave my brother my old bike with that crank, he worked the plastic end cap loose then sheared the teeth off the crank axle.....he's a pretty big unit mind. Can't dismiss the fact it was prob a maintenance issue too...........?
Posted : 26/06/2012 11:08 pm
