For the life of me I can't get my head around the DT Swiss spoke calculator. Would anyone be able to confirm the spoke lengths required for a Hope XC Rear Disc Hub with a Mavic XC717 (32 hole) Disc Rim?
Front
L251 mm
R 264 mm
Rear
L262 mm
R262 mm
paul
Speshpaul, I thought a rear wheel had different length spokes on either side?
use this one then..
[url= http://www.wheelpro.co.uk/spokecalc/ ]http://www.wheelpro.co.uk/spokecalc/[/url]
click hubs then select rear XC
click rims and select "Rim dia" and enter 559 (thats the diameter of a 717)
select the boxes for "Rim / Hub holes" set both to 32
click calculate
Disc side (Left) Cassette side (Right)
3x 3x
270.4 270.7
thats for 3 cross pattern.
dunno why there is 8mm difference though!!! thats a LOT!
I've just done the wheelpro one and its 262 for each side as well.
I'm pretty sure that a 717 disc is 542 not 559.
But i'll have to check now.
262 x 262 seems very familar, like lots of wheels.
Speshpaul not doubting you, i'm doubting me, i did get the size from "google" not Mavic direct.
Just looked on mavic and 559 is the external diameter of the inside of the rim-where the rim tape sits.
542mm is the diameter of the spoke holes.
with the correct inner diameter 🙂
it's 262.0 and 262.3 so paul was right. i got the outer diameter 👿 stupid CRC sizes/
thinking about it 559mm is the tyre size any (proper) MTB wheel googled with give you a diameter of 559mm.
So as my 1st post 262 for each side.
paul
"so paul was right."
Can i have that in bold capitals please 😀
Because it doesn't happen often.
OMG, what's going on. Is this some sort of secret code you are both speaking 😳
Yep, 262 for each side.
In a word yes!
Wheel building is witch craft, building a wheel is like joining a sect!
Don't worry about the above, you need 32 262mm spokes to lace a 717 disc to a Hope Xc rear, with a 3 cross pattern.
If you get stuck give me a shout, email in profile.
paul
PAUL WAS RIGHT!!
me = numpty 559 = mtb tyre size hahahaha should have known better
:-)Thank you.
I've noted today in next years calender so i can have a party.
Thanks guys (I think!!!!) 😆 🙄 😆
