Hoping someone can help me here.
Doing a quick service on some 2010 Fox Float 36 RC2 which has been dead easy so far. I'm now putting the oil back in, but not sure if I should be putting in 25ml or 5ml in the bottom of the legs.
Fox Oil volume chart [url= http://service.foxracingshox.com/consumers/Content/Service/oil_volumes.htm ]here[/url] no 52 says
FOX Red 10 wt. Damper 100.0 ml
FOX Green 10 wt. Damper-side O/B 25.0ml
FOX Green 10 wt. Spring-side O/B 25.0ml
FOX Float Fluid Air Chamber 5.0ml
I'm assuming that its the Open Bath figures but on the Mojo site it mentions 5ml (for 32 forks) so I'm wondering if its the bottom one...
The float chamber is between the top of the air spring and the top cap, and has 5ml of the thick blue 'float fluid'. 25ml of green 10wt goes in the bottom of each fork leg.
Cheers - all sorted now and feel quite slick now
