Hello,does anyone know the correct rear shock(fox ctd kashima )bushes sizing for a 2014 orange 5 se (medium 650b spec)? My bushes need changing and I'm not sure which mojo replacements I need. Would be much appreciated !
If you call mojo up they have a reference chart and will sort you out no drama.
Cheers for the info mate
m8 x 22.2 is what you need 🙂
Unless they've changed them on the newer fives, then they'll both be 12.7mm, 8x22
Are you sure now rickon....
Come on make your mind up...Only joking bud.. 😀
[url= http://www.tftuned.com/mount-kit-guide ]TF's guide.[/url]
Good luck fitting 22,2mm in there, the 21.8mm they come with are a pretty tight fit. Also,make sure the sleeve bolts don't get swapped front to rear, it's possible they may the same length again now, but until recently one was longer than the other.
^ This and after a repaint from orange i think mine now need about 10mm. 😆
That's weird. I ordered some 22.2 and they fit perfectly.
2 against one though, so must be 21.8.
