Help - Brake cable ...
[Closed] Help - Brake cable kits for Mechanical disk brakes
[#2268373]
Hi after a brake cable kit for a mechanical disk brake, Jagwire seem to do them but will they be long enough for a cross frame.
Any other suggestions gratefully accepted
Posted : 09/12/2010 4:08 pm
any long (single, continuous) brake outer will do. you can get long (30m ?) rolls of the stuff to cut to length or go to your LBS and ask for a measured length
Posted : 09/12/2010 4:31 pm
Does outer need to be continuous?
Am failing to see how a std cable won't work otherwise.
Posted : 09/12/2010 4:36 pm
just since he was asking if they'd be long enough al - you're right that interrupted runs would work
but full-length is better (ed: .. for keeping the shite out)
Posted : 09/12/2010 4:59 pm
