[Closed] help
[#2590718]
been tryign for over an hour to get my bloody tire off, snapped 1 tire lever already, 2.35 maxxis minions, whats best way, they just wont come off so annoying me
Posted : 23/03/2011 11:26 am
-let all the air you can out of the tube
-work the tyre back and forwards on the rim to loosen the tyres' bead as much as possible
-insert tyre lever( if you are snappng plastic ones try a solid metal lever)
-fix the lever onto a spoke
-insert second tyre lever under bead and work around your rim until the tyre is removed.
all the best.
Posted : 23/03/2011 11:37 am
yeh but when i squeeze the tire it sounds like airs just being pushed back in when i let go, ive been squeezing it out for ages and no different
Posted : 23/03/2011 11:39 am
take it to a shop.
Posted : 23/03/2011 11:45 am
Could try sticking a match stick or something similar down the valve to keep that depressed while you squeeze tyre ❓
Failing that tea spoon handles make useful metal tyre levers when previously there where none 😉
Posted : 23/03/2011 11:47 am
Try to make sure that the tyre beads are right into the well of the rim opposite the point where you are trying to get the tyre off.
Posted : 23/03/2011 11:49 am
yeh done it now, them plastic levers are crap im using a butter knife and it worked lol
Posted : 23/03/2011 11:52 am
