If you run a coil shock, how heavy are you in kit and what weight spring are you using?
Posted : 28/04/2011 8:32 pm
Posted : 28/04/2011 8:34 pm
no it recommends a 400lb spring for me and that is not right 🙁
Posted : 28/04/2011 8:36 pm
I had a 2007 latest shape with a Push'd DHX-5 Coil 400lb spring 90Kg in my gear.
Posted : 28/04/2011 9:30 pm
Older shape, 14.5 stone, 450lb spring. Probably a tiny bit soft if I'm honest.
Posted : 28/04/2011 9:33 pm
If you know the 400lbs spring is wrong as you've got one and can measure the sag, then this might be useful to help work out what you really need...
http://www.singletrackworld.com/forum/topic/maths-spods-spring-weight-question
Posted : 28/04/2011 9:40 pm
