Heckler Help Please
[Closed] Heckler Help Please
[#6056182]
Am trying to build up a 2008 heckler and I'm stumped with the rear brake fitting. I'm try to bolt on the IS adaptor and the shimano and hayes bolts I have, just won't fit through the frame's holes - they are too wide. Please collective, what do I need to do/ buy?
Posted : 21/03/2014 9:34 pm
Well, I apologise for the rest of the "collective" ignoring you in the first instance.
So, the brakes, as far as I know the IS standard uses the same bolts etc as every other. I can only wonder if the frame IS tabs are damaged in some way. Have you tried gently offering up the bolts without the adapter, just to see?
C
Posted : 21/03/2014 10:53 pm
Are you trying an older is standard disc, or a post mount disc using an adapter? Pics would help...
Posted : 21/03/2014 11:08 pm
I've got a 2010 Heckler, and had a 2007 one before. The brake bolts were absolutely bog standard on both.
Posted : 21/03/2014 11:37 pm
had one of those, the normal IS mount fits fine, what do the threads look like on the frame?
Has the frame been painted or coated ?
Could be the holes or threads need cleaned up.
Posted : 21/03/2014 11:53 pm
Frame been resprayed at all? Should be standard bolts.
edit - beaten to it 🙂
Posted : 21/03/2014 11:55 pm
 st
I had this on mine, the clearance in the 'outer' holes is tight which is an issue as the bolt heads fit inside the mount rather than surface fit. Luckily I have a little box of bolts and had alternatives that fitted.
Posted : 22/03/2014 11:18 am
 bish
Do the mount bolts have washers on them? I had this problem with shimano mounts so just used different bolts
Posted : 23/03/2014 9:24 am
I found the Avid bolts fitted perfect shimano with washer where to big, 😀
Posted : 23/03/2014 9:28 am
