Headsets with moder...
[Closed] Headsets with modern frame head tubes
[#5575446]
So the majority of frames are now either full 1.5 (49mm) or 49mm at the bottom and 44mm at the top (tapered) head tube.
So when buying a decent quality headset what is the most common setup?
I have a full 49mm head tube so went for a chris king inset 5 however having a lot of trouble stopping the top headset cap from moving. There is literally no insertion in to the bearing.
Can't help but think its a poor design.
Do most folk go for a full outboard set up like the devolution or is the Inset a popular choice?
As someone had suggested I have checked its not my headset spacers moving. They are within tolerance and the top tap is simply moving under pressure.
Posted : 05/10/2013 2:17 pm
Tapered on a Blur LTC and I use Hope Top is a number 2, bottom is an F, fitted in 2 identical frames perfectly.
Posted : 05/10/2013 2:20 pm
Thanks, for some reason I never thought of hope. Was just liking at king and cane creek.
I'll have a look at the hope design.
The inset design isn't the problem on the king, its the top cap and how it sits on the bearing. It's a flimsily piece if alloy with such little contact area.
Posted : 05/10/2013 2:33 pm
The hope comes with a set of shims that you can use to get the right position for the top piece of the headset (fitted the last one yesterday and it's 3 out of 4 for the Blur)
Posted : 05/10/2013 2:35 pm
