It is ages since I had to fit a head set and feel a bit lost with the new sizes. Anyone expert enough to point me in the right direction.
I have measured the top bore of the headtube 41.9mm with a 3mm recess bore. Bottom bore 51.8mm with 7.5mm recess bore. See pics. Had a look at the Hope size guide, but could not match anything. Charge say use an FSA set, but the one recommended takes a tapered steerer and I have a straight 1 1/8th steerer.
Can anyone point me in the right direction? Thanks
Use the recommended fsa one and a hope crown race reducer for £8 [url= http://www.wiggle.co.uk/hope-15-headset-reducer-crown-converter/ ]bing[/url]
Recently done this with Cane Creek. Top and Bottom are different headsets so you cant buy one and it fits both parts. I bought the following:
Upper:
[url= http://www.chainreactioncycles.com/cane-creek-40-series-is42-top-assembly/rp-prod115645 ]Cane Creek is42[/url]
Lower:
[url= http://www.chainreactioncycles.com/cane-creek-40-series-is52-30-bottom-assembly/rp-prod115642 ]Lower Cane Creek is52[/url]
Brilliant, Thanks!
