Headset Identificat...
[Closed] Headset Identification
[#4030953]
I have a Yeti SB95 on order and am trying to sort a headset before it gets here. Yeti say that is is an Inset Zerostack 44/56mm.
Going by this:
http://www.evanscycles.com/categories/components/headsets/f/hope#!
Which top and bottom cups do I need? Have phoned Evans but they did not have a clue. Cheers.
Posted : 02/06/2012 10:30 am
This is useful for getting headset info.
http://www.canecreek.com/headset-fit-finder
Also, if its Chris King you're after ring Bike Chase. They have lots in stock. 01889 575170.
Ask for Jack.
Posted : 02/06/2012 10:43 am
Careful with that Cane Creek guide, the first two frames I tried out came back with headsets that wouldn't fit.
Posted : 02/06/2012 12:00 pm
Thanks but as I dont have the frame yet that guide is not much use.
Posted : 02/06/2012 2:49 pm
You "probably" need (in CaneCreek's terminology):
top ... [b]SHIS:ZS44[/b]
bottom ... [b]SHIS:ZS56/30[/b]
Assuming that you're using a non-tapered 1.125 steerer.
Of course, if you're getting a tapered steerer fork, you'll need a different bottom. If you're using a full 1.5 steerer you 'll need different top and bottom.
If all that means nothing to you... get whoever you're buying the frame off to fit the correct headset.
Posted : 02/06/2012 4:06 pm
Oh, and buy off someone who'll help you. Avoid Evans.
