hayes hfx 9 problem...
[Closed] hayes hfx 9 problem !! help me please!
[#722686]
i bought a set of hayes hfx 9 off here the other week and they have been fine apart from the front brake dragging a bit.
i thought it might have been to much fluid in the lever so earlier i took the ca off the reservoir and let a little fluid out.
when i first ut the cap back on the brake felt fine , but as i kept pressing the lever it got spongier and spongier tothe point wer now it comes right back to the bars and does nothing??
have i broke it or can it be fixed??
help as im off to wales on saturday and need a front brake.
Posted : 20/07/2009 8:52 pm
 dobo
it sounds like it just needs bleeding, i'm sure there are tutorials on the web to tell you the best way or failing that the hayes manuals, thats how i bled mine first time round.
just need to get yourself a bleed kit, or google for a diy hfx 9 bleed kit
Posted : 20/07/2009 9:18 pm
wot the said, they aren't to hard to bleed at all.
Posted : 20/07/2009 9:38 pm
http://forums.mtbr.com/showthread.php?t=206276 😆
Posted : 20/07/2009 9:41 pm
cool link!! will give that a go
cheers
steve
Posted : 20/07/2009 9:42 pm
Just be patient with the bleeding and dont forget to squeeze the syringe while pumping the lever to make sure all the air is out.
Posted : 20/07/2009 9:49 pm
