Hardrock groupset u...
[Closed] Hardrock groupset upgrade
[#5899492]
Hi guys,
Will this groupset fit my 2010 Specialized Hardrock?
[url= http://www.ebay.co.uk/itm/2014-Shimano-SLX-3x10S-8pc-31-8mm-Group-Set-M670-M675-with-Brake-170mm-Black-/141120804481?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item20db749681 ]SLX groupset[/url]
My main question is around the crank and bottom bracket. Will any groupset fit the Hardrock or is there a certain size?
Here is the original [url= http://www.evanscycles.com/products/specialized/hardrock-comp-disc-2010-mountain-bike-ec019398#features ]Hardrock spec[/url]
The original bottom bracket is a Shimano BB-ES25, Octalink spline, cartridge bearing, 68mm x 118mm
Will the above groupset fit this frame?
Thanks guys.
Posted : 28/01/2014 3:06 pm
That will all fit fine however I'd question why your doing it. SLX is a great groupset, I use it on my Ibis but I think you'd see a much bigger performance hit for that money on frame and fork. Just a suggestion on my behalf don't take it too heart but yes that groupset would fit fine and could be moved onto a new bike down the line.
Posted : 28/01/2014 3:11 pm
Hi Ross thanks for the feedback. I've already upgraded to a Rockshox Recon fork, and changed the wheels to Shimano Mach 1s.
I like the Hardrock frame, plus also it keeps everyone else's expectations low when you arrive on a Hardrock!
So if is strip the frame and dump everything off it that groupset (which includes brakes) should be fine? There are no implications in changing the bottom bracket? The new SM-BB70 Bottom Bracket would fit the Hardrock frame?
Thanks for the advice!
Posted : 28/01/2014 3:19 pm
As above, it'll fit fine, but for me wheels and fork would be first. The frames are actually pretty good..
The stock wheels and fork are heavy, you'd shave lb's off it with some Hope hoops and a Reba/fox 32 upgrade..
Posted : 28/01/2014 3:23 pm
Yes the slx chainset and bb will fit but it would not take much to find a much nicer frame.
Older m5 rockhopper frames are very good and cheap
Sounds like you've got the upgrading down to a tee! The BB is a different style and will require a new tool if you're doing it yourself however it'll fit fine, They come with 3 little plastic spacers to enable it to fit 68 or 73mm bbs. Your current brakes are Avid but i'd just bolt the new brakes to the old adaptors and rotors as you dont get new ones with that groupset it'll work fine unless anything is wornout.
EDIT: If you do get the groupset I'd get it from Merlin, A fair bit cheaper, in the UK not China and you get rotors : http://www.merlincycles.com/shimano-slx-m670-triple-groupset-sale-65626.html
Posted : 28/01/2014 3:26 pm
Wow - thanks Rosss!
There is only the "top swing" in stock. Is that the one I need? Has cables as well as rotors!
Posted : 28/01/2014 3:36 pm
Last question.
Could you tell me what the difference (other than £50) is on these two packages? The are both group sets with brakes right?
[url= http://www.merlincycles.com/shimano-slx-m670-triple-groupset-sale-65626.html ]Groupset One[/url]
[url= http://www.merlincycles.com/shimano-slx-m670-triple-10-disc-brake-groupset-58861.html ]Groupset Two - £50 more[/url]
Posted : 28/01/2014 3:52 pm
In it's most basic form top swing refers to where the clamp is in relation to the cage of the front mech if I remember correctly. Don't take my word for it but I think the seat tube is regular and straight to the BB so it wouldn't matter either way as there is nothing to obstruct the mech? As for the groupsets i'm not sure what the difference is, I think the cheaper one is a one off deal where as the more expensive one allows you to chose cassette range. Once again don't take my word for it but i'd be good if someone could correct/agree with all that.
Posted : 28/01/2014 4:01 pm
299.99 Has SPLINED rotors - do not buy unless you have shimano centrelock (rahter than 6 bolt) hubs (although you could flog the rotors and would probably get a pair for less than the difference)
Posted : 28/01/2014 4:07 pm
RIght - I have Shimano 475 6 bolt disc hubs so i need the more expensive package I guess
Posted : 28/01/2014 4:09 pm
I highly doubt they'll give you adaptors for the brakes anyway so i'd get the cheaper package and just sell the new rotors on and buy the ones you need as and when. Simpler that way and you could easily buy two new rotors for less than the £50 difference
Posted : 28/01/2014 4:11 pm
Aye, true enough, just buy it and use the rotors you've got for now
Posted : 28/01/2014 4:13 pm
The cheaper package has a 180 front rotor. I currently have 160mm rotors front and rear so I guess I should get a front rotor too and some new brake cables 🙂
Thanks for all the advice guys - you really helped a very confused newbie!
Posted : 28/01/2014 4:23 pm
No just stick with what you've got, no cable required as they're hydraulic brakes. The brake callipers will just sit in the adaptors you've already got on your fork (unless post mount in which case will the calliper will bolt straight to the fork) and rear brake mount. I'd advise getting someone local who knows their way around a bike to show you.
Posted : 28/01/2014 4:29 pm
D'oh! course no cables!
Thanks again!
Posted : 28/01/2014 4:35 pm
Matey,
noticed your are in shropshire, me to. email me if you need anymore help.
cheers
paul
paul.sal AT btinternet.com
Posted : 28/01/2014 5:05 pm
SLX Brakes £110
SLX Crank £90
XT Cassette £37
SLX Gear leavers £43
SLX Rear Mech £35
KMC X10 Chain £20
SLX Front Mech £20
Total £355 but you get an XT cassette which might be important if you ever consider going 1x10 with a 42t cog.
I would suggest you consider 1x10 anyway that would mean not getting a front mech and not getting that pair of levers but getting a Zee one instead that would be £43 less. Then spend £35 of that on a Narrow Wide chain ring, you could also consider ordering a 42t cog for your cassette. This would give you a range of 11-42t very similar to SRAM 11 speed sets 10-42t.
You may not want to do this but if you are buying a new groupset I would at least think about it.
Posted : 28/01/2014 5:15 pm
