Groupset dying…wher...
Groupset dying…where to next?!
[#12613355]
The groupset on my trusty BMC Aplenchallenge hybrid/gravel/commuter bike is on its way out so will need renewing in the new future
Currently have Shimano Sora 2x9
50-34 up front
11-32 in the rear
I’m looking at possibly going to a single chainring up front as I rarely use the smaller chainring…But what to go for?!
Happy to keep the 9 speed cassette as is but wondering what chainring would give me a decent spread of gears for (give or take) 80% flat-ish (mostly city) commuting
20% hills and climbs
I only use the smaller chainring on one hill (12% incline for around 0.4 mile) and only go halfway (at most) up (or is it down?!) on the cassette when I do
Something that will let me go quick on the flats and handle climbs without grinding up, prefer to keep the crank arms if possible so something compatible with those would be ideal
Suggestions please…many thanks
Posted : 12/11/2022 10:39 pm
Crank arms are the same as these
https://ibb.co/ctd6LbG
Posted : 12/11/2022 10:43 pm
Well this is bargains season, so scan through the different sellers/shops/outlets and whatever is the best price/biggest saving go with that. Even if its mix n match.
Posted : 12/11/2022 10:49 pm
Ha ha I guess you’d call that good timing
Mixing and matching is fine as long as it works
Just need advice as to what size chainring would be a good option as a single ring given my requirements and which would be compatible with my crank arms
Posted : 12/11/2022 11:18 pm
 irc
Stick your current gears in this calculator. It will give you a list of your current gears in your choice of output. I like gear inches.
Then try different sizes of single front rings with different rear cassettes.
https://www.sheldonbrown.com/gear-calc.html
My approach is to start with what is the highest low gear that is acceptable. Then compromise on top end.
For what it's worth around town my 1x9 bike has a 38t front and either 11-32 or 1134 at the back. Can't remember offhand. Gets my up the hills I need to and spins out around 23/34mph. I'mm more of a spinner than most people. Starting of with a 42T ring in the gear calc might work. Or 44.
PS - The starting point for chainrings fitting the crank arms is the BCD
https://www.wolftoothcomponents.com/pages/how-to-measure-bolt-circle-diameter-bcd
So most chainrings with a matching BCD should fit your crank arms though sometimes a few minutes with a file is needed.
Posted : 12/11/2022 11:57 pm
I think that the Sora 9s is a 4-arm 110BCD (check this-I haven't 🙂 )
Size of the chainring is going to have to be down to you using a gear table as suggested by irc^^
If you use an outer Shimano chainring alone then they are expensive. The inner is cheaper but won't give you the higher gears
I'd buy a single chainset from somewhere like Spa Cycles https://www.spacycles.co.uk/m8b0s109p0/Drivetrain/Chainsets and a BB to give you the correct chainline
Posted : 13/11/2022 8:34 am
