Grips & Hairspr...
[Closed] Grips & Hairspray ?
[#4147520]
Hi,
My foam grips are rotating, they are brand new as are the bars.
I've read about using hairspray to keep them in place. Seems sensible enough.
My question is though, if/when the grips need to be removed what is the likely hood of the hairspray damaging carbon bars ? How would i go about getting them off without damaging the bar ? The grips are only £10 so i'd happily cut them up etc.
Posted : 09/07/2012 10:18 pm
A zip tie and a squirt of WD40 or GT85 will do the trick. Clean them off afterwards and you can use them again.
Posted : 09/07/2012 10:19 pm
Ok.
I gather the hairspray wouldn't lift the lacquer on the bar ?
Posted : 09/07/2012 10:22 pm
Doubt it, it's pretty tame stuff, it's designed for you to spray it onto your head after all...
I should add that I've only ever used lock-ons on carbon bars so someone could well come along with horror stories of delaminated bars shortly.
Posted : 09/07/2012 10:25 pm
Very true, can't be "that strong"
Posted : 09/07/2012 10:34 pm
I've used the hairspray trick with carbon bars and foam grips before, when it comes to removing them just try and get some warm water under them and they should still come off without cutting.
I now use ESI foam grips on all my bikes and find they never slip, would highly recommend them if you're having a problem with other foam grips slipping and don't want the hassle of using hairspray or similar.
Posted : 09/07/2012 10:36 pm
 AD
I've used hairspray to attach Ritchey WCS grips to Easton EC70's for the last 5 years - haven't failed (yet...)
As to taking them off - just pull really hard - I'd be wary of using a knife.
Posted : 09/07/2012 10:40 pm
OK, will pinch her hairspray tomorrow 😀
Posted : 09/07/2012 10:41 pm
Yep, been using hair spray and foam grips for years.
So far as getting off, one of those rubber coated steel screwdriver style tyre levers to lift the grip without scratching the bars and then loads more hair spray.
Posted : 09/07/2012 11:18 pm
Just make sure it's the cheapest hairspray you can hold of- the good stuff isn't as sticky
Posted : 10/07/2012 5:51 pm
This brings back lots of memories.
Using hairspray as a lube & adhesive for grips is very old school & yet it still continues to be one of the best. Been using it since late 70's first for tri bar grips on road bikes then carried on through every MTB I have had.
One warning though you MUST use the cheapeat nastiest hairspray you can get, the more expensive stuff is now designed not to be sticky so it wont work. If you can get it the basic Insette in a blue & white can that sells for 69p near me is the one I have always used.
Posted : 11/07/2012 1:00 pm
Cossack is the only hairspray you'll ever need (for your grips)
Posted : 11/07/2012 5:01 pm
Make sure you get unperfumed...
I use extra firm hold.
Posted : 11/07/2012 5:38 pm
3M spray adhesive fixes them on better, but is harder to remove. Resists water a lot better ime. Agree with wolfy above tho, if you use hairspray get the cheap stuff.
Posted : 11/07/2012 5:45 pm
I put the grips on last night, removed them and cleaned them and the bars with IPA.
Sprayed some hairspray on (Firm hold from vella) and left them overnight.
Checked them this morning and they are solid 😀
I've no idea if vella is a good/cheap brand....
Posted : 11/07/2012 6:16 pm
I used golden syrup on shinsplints bike as he had nothing else. Solid in a few days 😀
Posted : 11/07/2012 6:21 pm
My wife made me watch hairspray, didnt enjoy it much, not heard of grips is that a musical too ?
Posted : 11/07/2012 7:04 pm
more hairspray removes them easily.
Posted : 11/07/2012 7:52 pm
 teef
Splash out on some lock on grips - Superstar do them for £10
http://superstar.tibolts.co.uk/index.php?cPath=60&osCsid=h3aimb2k83j5btukqsrkffo8a6
Posted : 11/07/2012 8:46 pm
