[Closed] Grips
[#10845862]
A broken thumb and a broken wrist this year with the seeming lack of ability to do sufficient physio and unable to stop doing the things that aggravate the injury means I need to figure out a grip solution.
ESI's have been good but I need something for the winter bike tha'll hold up a little better to the inevitable..
WIth the UCL pain, I'm tending to load the outside of my hand to de-weight my thumb joint. I have some Ergon GE1 evo factory on 800 bars but they are really firm.. very little cushioning.
What else is out there?
Soft thick Deathgrips, SQLabs 70x/711 or just be prepared to replace the ESI's if i tear them?
Some added width with a tapered inner would be nice.. this is one of the limiting factors with ESI's on my current bars as they're 760's wheres as I'd normally run esi's on a 800.
Or new Oneup bars perhaps and stick with ESIs
Tia
Posted : 04/10/2019 3:27 am
I just got some of the PNW Components Loam grips (15% off with code ENDOFSUMMER)
and they’re really soft. Really pleased with them especially as with the old hard grips I had before I was getting some tennis elbow like pain on longer rides, but in the couple I’ve done on these since I’ve not had any of that pain at all. Which is I think due to them being a bit bigger. Only took a few days for them to arrive from Sacramento too.
https://www.pnwcomponents.com/products/loam-grips?variant=30228318781517
Posted : 04/10/2019 4:04 am
They look interesting, do they add any bar width?
Posted : 04/10/2019 4:27 am
They aren't as long as the syncros grips I had (same length as the deathgrips I had), so my hands are further out on the bars and had to move the brakes etc out a bit to get them in the right place. So in effect they add a bit. I've also seen people run these type of grips a few mm out rather than butted up to the end of the bars. Not sure if the manufacturers would recommend it.
Posted : 04/10/2019 6:09 am
Check out the new ODI dreadlocks, they seek to tick all the boxes you mentioned.
Posted : 04/10/2019 8:14 am
I had been interested in trying a pair a pair of these, so went to order a set with the code above (thanks) but they want $40 shipping!!!
Posted : 04/10/2019 8:20 am
Mine were free shipping, so not sure happened there. Might be a glitch in their system, so could be worth contacting them?
Posted : 04/10/2019 8:31 am
https://www.planetx.co.uk/i/q/BTOOHBF/on-one-half-bob-lock-on-foam-grips £3 at mo, very comfy on Knuckleball "chewy" bars for the past ~2+ years.
Posted : 04/10/2019 8:38 am
I use ergon gp1 grips, I literally can’t ride with anything else nowadays.
Ymmv, of course.
Posted : 04/10/2019 9:34 am
Ergon GA3 grips are working for me.
I was suffering from Cyclists Palsy and they have helped tremendously by taking some of the weight off the heel of my hand.
Posted : 04/10/2019 9:55 am
