My edge keeps turning itself off....Done the reset and still faulty.Has anyone used ther $79 repair service?
call them, they might even do it for free (UK)
What is the repair service offer? I have cracked the LCD screen in a crash, and its 'bled' so only about 25% of the screen is visible - but it still works! won't last much longer and i presumed id have to bin it if it bleeds much more. Do they repair for a fixed price?
My Foretrex was done for a flat fee of £56 IIRC. Whatever they would have done to it same price. They sent me a new one.
Have you updated the firmware as this happened to mine, I updated to the latest firmware and bingo it seems to be fine now.
they'll most likely fix the edge for free if it's still in warranty - it's a common fault
its out of warranty
£46 for an exchange replacement, which comes with 12 months warranty
This is what I was quoted last week
mine is a totally different problem where it'll only turn on with a full reset
All becuase I left it on charge until I next wanted to use it, seems they don't like this
Definitely worth a phone call to Garmin.
Had a similar thing with my edge when it kept turning itself off on bumpy trails (yeah, I know)- started looking at prices for a replacement, as mine was out of warranty, but gave them a call anyway.
Told them the serial no. and they confirmed that there is a known fault with some battery connectors and that mine was a faulty one and would be replaced with a recon unit if I sent it back to them.
One postage cost and three days later - problem solved. Good luck
interesting cause mines does this - i started using sports tracker cause of it ....
will be getting a call i reckon 😉
The Edge turning off is because the unit is made in 2 half's. The battery is in the bottom half and connects to the top via contacts, eventually the contacts wear and the unit looses power during a ride. The unit can be taken apart (info on the web). One thing to try is to compress the unit in the contact area (Directly below the USB connection). I use a piece of inner tube (20mm wide ish) wrapped around the top a couple of times really tightly.
numlock - MemberThe Edge turning off is because the unit is made in 2 half's. The battery is in the bottom half and connects to the top via contacts, eventually the contacts wear and the unit looses power during a ride. The unit can be taken apart (info on the web). One thing to try is to compress the unit in the contact area (Directly below the USB connection). I use a piece of inner tube (20mm wide ish) wrapped around the top a couple of times really tightly.
My 60 csx had the same problem. Bending the 2 contacts sorted it out.
Here's how to fix the problem [url= http://www.tracklogs.co.uk/cgi-bin/publ/user.cgi?obj=support&mod=kbase&view=23851013 ]- Linky[/url]
My edge 305 just started switching off.
I phoned up Garmin, and apparently mine isn't in the batch with the problem and it is £65.24 plus postage for a refurbished one. That is significantly more than $79. What a rip off
I'll have a go at repairing it myself, and if not put the money towards a 705
