Saw this question on another forum, and no-one answered it. Not sure if that's because they couldn't answer it or if it just didn't interest anyone.
Given that the standard advice is usually "get the best frame you can afford" what are the criteria of a good frame? Test rides aside, what do you look for in a frame?
Geometry, weight, brand, warranty- usually in that order for me.
Possibly because it's hopelessly vague and subjective?
Somewhere to put a water bottle would be my shout.
It’s a question that’s going to depend very much on budget, intended use and preferences. I’d probably mostly go along with chilled, but I’d consider material and frame designers’ reputation alongside weight and purpose I think.
Overall, questions like this and the ‘what are your go-to brands’ from before Christmas don’t really worry me too much and seem a little out of place on STW to me.
I just spent a very long time evaluating a new bike purchase base on geometry, specifically reach and head angle. I used all the annoyances and likes from previous bikes, plus internet reviews and science to understand my likes and dislikes and how those things would influence my riding.
Having found two bikes I want that fitted all that AND my intended application, I then waited for mag reviews and other peoples experienced to validate how things like the suspension "felt" to compare with my own views before finally making the leap.
I've ended up with the frame and kit that fits, suits my riding and feels exactly how I wanted it to feel.
Yes, it was a tedious process, for others as well as me...
OK, let me clarify my point.
I am not talking geometry/fit/reach/or if it has a bottle mount.
What makes a frame a "quality" frame? Manufacturing process/materials/design elements etc.
I'm not sure you can separate geometry from design really. Geometry is the biggest part of it, it is racey or comfortable, does it suit your local riding? Material, then quality of that material and tube profile come into it. Will it be stiff if you want stiff, or forgiving if you want forgiving? After that it's probably finish and colour. If it's a MTB what's the shock like too.
Yes.
And headtube badge.
Seems I`m overthinking this 😳
If you know what geometry you want I am presuming you could find plenty of different frames that match that requirement. What else sets them apart?
So no-body looks into specs of aluminium or carbon, or looks at the quality of welds, or the style of dropouts or stay bridges or anything else? Do you all part with your hard earned so easily? Find one the right shape, and pick a colour?
it's a bike, for splashing in puddles and doing wheelies, how hard does to have to be?
Given that the majority of higher end frames come out of the same half dozen factories.
Actually finding what materials use is nigh on impossible (them saying 'high mod' means close to bugger all) and you'll never get access to lay-up schedules.
I've seen the inside of some very expensive frames...it would upset you.Have a look at Luescher Teknik' s YouTube channel.
Then yep....pick colour,pick this weeks 'in' geometry and fill yer boots.
In the real world the thing that will make the biggest difference to you will likely be the warranty support you get if it goes pear shaped.
So the standard advice of "buy the best frame you can" is BS IYHO?
I`m not asking because I am buying a bike BTW. I am just curious as to what other peoples criteria of a "quality" frame is.
For me.
One that's ace at splashing in puddles and doing wheelies....and has somewhere for a water bottle.And has a good warranty.
Well, was taking it to the extreme but how much time and effort are you suggesting people put in for a nonessential leisure purchase? half an hour on the internet looking for 'my bike fell in half' stories would about do it for me, after that: does it look cool, is about the right geo, what's the suspension like (if it's got any), will my bits fit?
trailwagger - Member
Seems I`m overthinking thisIf you know what geometry you want I am presuming you could find plenty of different frames that match that requirement. What else sets them apart?
If you're leaing that stuff out of it, then since you can't really test frame for quality in any meaningful way, it becomes pretty subective - things like warranty, brand reputation, past experience of the brand by yourself or people you know, etc.
Pretty paint and that it fits me, water bottle points are a bonus
I'm fussy about stack height. most of my frames have slammed stems (for the insta love :lol:) so i don't like tall front ends.
in a road bike context don't get cheap alu, get a top end alu frame. don't get cheap carbon get top end carbon. etc etc.
If theres an alu/ carbon choice then choice is more difffiuclt. There is a perception that ridley are beter than trek and storck are better than both (for example) although i think that's 90% branding and heritage and 10% factual.
mountain bikes are a bit more complicated as suspension design is far more important than material quality imo.
Kryton57 - Member
Really? You’ve changed 😉
Ignoring:
Mine were as follows:
Essential:
Seat tube less than 440mm
Reach more than 435mm
Head angle less than 65.5deg
Stealth dropper cable routing
Rear travel more than or equal to 150mm
Ideal:
Threaded bottom bracket
External brake hose routing
Shimano direct mount mech hanger
Good warranty
1x only frame
This probably isn't very helpful to anyone else though... (You'll also notice that weight and frame material didn't make it to my list.)
Quality is a subjective term and is purely dependant on a given product satisfying the purchasers criteria....whatever they may be.
A Kia Cee'd is just a high quality product as a Rolls-Royce for some customers.
I'll tell you what 99.9% of us really don't want, but unfortunately think we do...that is the same frame the professionals ride of whatever cycling discipline they follow.
