Glueing the ends ba...
[Closed] Glueing the ends back on bars...
 gee
[#5275456]
So I'm trying to be a bit tight and not fork out £60 on bars that are 1" wider.
I found the two little 1/2" bits of carbon bar I cut off the ones on my El Mar ti on the garage floor this evening. Shows how much I clean my garage as they were fitted in March 2011.... Two dabs of superglue later and my bars are back to full width and £60 saved. I reckon the lock-ons and their hard plastic inside bits will distribute the weight along the bar enough that it won't be an issue...
Hopefully.
Will I die?
GB
Posted : 24/06/2013 6:22 pm
Why bother with the bar tips? Just move everything out half an inch so the grips hang off the edge. Save a bit of weight too???
Posted : 24/06/2013 6:32 pm
Ive ridden a DH bar that someone did similar on, was fine. My concern in this situation is your now only using 1 lockon collar to hold the grip onto the bar, on a carbon bar, far from ideal.
Posted : 24/06/2013 6:35 pm
 gee
Most non-ODI grips only have one lock-on collar so that's no a problem.
GB
Posted : 24/06/2013 6:38 pm
Since getting a dh bike with 800mm bars my 680's on my normal bike have felt way too narrow to the point where I'd started to go off the whole bike. The other night I chopped 40mm sections off an old set of bars and used them as inserts for the outer lock on clamps to grip. I was expecting it to be a fairly flexy bodge to let me see if the wider bars made a difference. In reality the whole things very stable, I like the width and although I've every intention of getting a proper set of bars there's a strong possibility the same three piece bars will still be in place this time next year 🙂
Posted : 24/06/2013 6:45 pm
Will I die?
Not if you used araldite - epoxy and carbon is a potent mix - but I dont beleive that cyanoacrylate is the best substitue, rather brittle.
I only ask that when you test it you have a mate handy to record the result?
Posted : 24/06/2013 6:55 pm
 gee
Araldite would have been a better bet... I do have some, just didn't think to use it!!
Fingers crossed.
GB
Posted : 24/06/2013 7:08 pm
I think the saying goes 'check twice, glue once' doesn't it? Well, something like that anyway 😕
Posted : 24/06/2013 7:16 pm
With your track record at race starts, this idea seems BAD to me!
Posted : 24/06/2013 7:30 pm
If it's for real and not a wind up then it's got to be one of most stupid things I have heard someone do with a pair of handlebars.
Posted : 24/06/2013 7:35 pm
 gee
Thanks for the vote of confidence Dave.
For the record, that was my cleat shearing in half...
Oh and I don't think it's that daft - only the same as overhanging the grips by 1/2" and some lock on grips only have one clamp so no issues with only having one.
GB
Posted : 24/06/2013 7:36 pm
