Getting oily drivet...
[Closed] Getting oily drivetrain gunk of carpet.
[#5279876]
Any ideas appreciated guys.Made a bit of a mess trying to clean my GT in the flat.
Posted : 26/06/2013 12:18 am
A rug 🙂
Failing that some washing up liquid (small amount) after that a carpet cleaner might do it.
After that a rug.
Posted : 26/06/2013 12:21 am
Auto Glym tar remover,
That stuff will shift it ! Let me know how you get on ?
Posted : 26/06/2013 12:42 am
TF2 or GT85 is good then some soap.
Posted : 26/06/2013 12:43 am
Don't worry mike,a rug or runner was my first idea.Trouble is the stains are near a door and may catch on opening.
Posted : 26/06/2013 1:02 am
Vanish power foam - big pink aerosol of the stuff - its some kind of voodoo magic - not yet had anything that it wont shift....
Posted : 26/06/2013 1:10 am
WD40 is worth a go.
Posted : 26/06/2013 1:33 am
GT85 always works for me.
Posted : 26/06/2013 5:57 am
Posted : 26/06/2013 6:04 am
Anything with limonene in it works really really well.
Posted : 26/06/2013 6:28 am
Neat Fairy Liquid (other brands are available) did the job on an oily chainring mark on my stairs that had been there for months - put a decent amount on, work it in and then rinse it off a few times (wash-vac good for the last step).
Posted : 26/06/2013 7:29 am
If all else fails and you're really bothered, get a professional carpet cleaner in. I have a mate who does it and the results are impressive.
Posted : 26/06/2013 8:06 am
Hairspray. I think the alcohol in it is what helps, although not sure. In any case, and old shop trick - whenever I get oil on clothes, just shoot some hairspray on it and chuck it in the laundry, usually works.
placing a loved ones favourite garment within about 5 feet of anything oily is normally enough to ensure full transfer, ime.
Posted : 26/06/2013 8:08 am
You need to dissolve the greasy stain first with something like paraffin or Swarfega. Actualy Swarfega is a better idea because it won't soak into the carpet like paraffin and it's water soluble. Then wash and dry, wash and dry until it's all removed from the pile.
Posted : 26/06/2013 8:12 am
FinishLine citrus degreaser I found to be ace.
Posted : 26/06/2013 8:20 am
IPA and then draw it up with some kitchen roll.
Avoid anything with solvents that might affect the colour of the carpet.
(test anything you use on a small bit somewhere)
Posted : 26/06/2013 8:22 am
Copious amounts of brake/clutch cleaner and a good scrub worked for me in the past, basically pure alcohol so evaporates without a trace.
Posted : 26/06/2013 8:38 am
Baby wipes
Posted : 26/06/2013 8:40 am
off....
English 101.
Posted : 26/06/2013 8:43 am
"IPA and then draw it up with some kitchen roll.2
Greene King?
Posted : 26/06/2013 8:44 am
I bought some carpet cleaner from Home Bargains for about £3 a while ago, only just started using it and it gets rid of dirt like it was never there.
Posted : 26/06/2013 8:46 am
Rub your calf up against it? Seems to be a magnet for it whenever I've over-lubed my chain.
Posted : 26/06/2013 9:29 am
Just remember - you'll probably need to clean the rest of the carpet afterwards otherwise they'll be one patch much cleaner than the rest so whatever you use buy plenty of it. 😉
Posted : 26/06/2013 9:52 am
White wine vinegar?
Does just about everything so worth a shot.
Posted : 26/06/2013 9:53 am
