Xmas pressie, appreciate it wont show an OS map to follow but I believe you can upload a route to it??
[url= http://velogps.com/garmin-edge-200-turn-by-turn-directions/ ]This should help ;)[/url]
Create your route using whatever tool you prefer. Usually you can save this as a GPX file but turn-by-turn instructions aren't created/saved in that format so you need to convert it to a TDX file. An on-line utility like bikeroutetoaster.com can do this for you.
Now that you have your TCX file you need to get it on to the unit. Plug it in to your computer and navigate to it using Explorer/Finder. You should find a folder in there called "New Files", copy the TCX file to that folder. The next time you start the unit it will take your route.tcx file and convert it to route.fit and move it to the courses folder.
That's it!
bump
