FSA Comet Fat crank...
[Closed] FSA Comet Fat crank with Hope BB?
[#8376921]
Specs say 24mm, Google says grease and a whack. It went in, nipped up nicely and spun freely. But on removal the driveside bearing came away with it. Any ideas?
I realise it should be a GPX Bb but what's the difference?
In the past I had a Truvativ crank and required an extra spacer inside the bearing but this clearly doesn't.
Posted : 28/02/2017 4:56 pm
I can slide a megaexo into a shimano BB no problem. its a nice snug fit that indeed needs a bit of persuading with a rubber mallet.
I think your issue is simply that of tolerances. Perhaps hope use 24mm- whereas maybe FSA are 24mm+
(I've a feeling that truvative 24mm doesnt work with other 24mm)
You'll need to free the bearing off the spindle I guess, as I assume that you removed it to change the chainline?
If everything lines up just fine, then can you just reassemble?
Posted : 28/02/2017 7:02 pm
Thanks bearback, I've got the bearing off. The chap I bought the crank off is sending me the proper BB, I'll see what the difference is.
Posted : 28/02/2017 11:22 pm
I'm not sure about the Comet arm set, but other NBD (no pinch bolt) cranks use a sprung wave washer (in addition to solid 1mm spacers) to set preload.
Not 100% sure, but I believe the corresponding NBD BB has a lip on the outer face of the dust shield whereas pinch bolt BB's are flush. I dont think theres much to this aside from how the BB's seal with wave washer vs pinch bolt preload.
Posted : 01/03/2017 3:33 am
This one uses the wavy washer, I'll check out the seals once I've got the BB
Posted : 01/03/2017 6:54 pm
