front mudguard for ...
front mudguard for rigid forks?
[#13038804]
what's out there?
needs to fit 29er, 1" steerer and 2.25 tyres
Posted : 11/11/2023 11:25 pm
Came to say Velo Orange 63, but they're max 2.2". And they mean it, the extra 6mm of a 2.25" wouldn't fit.
Some things that might be useful though:
Problem Solvers Fender Flute
Portland Design Works Safety Tabs
Mud flap (either buy or make out of damp proof course)
Posted : 11/11/2023 11:35 pm
Mudhugger? I don't have any problems fitting them to rigid forks.
Posted : 11/11/2023 11:59 pm
supernova and supernova reacted
Crud X-Large.
Posted : 12/11/2023 12:05 am
Udhuggerhere aswell
Posted : 12/11/2023 8:16 am
Rrar crudguard fitted into steerer via a cork and a woodscrew, with a set of U stays adapted from some velo orange spares?
Posted : 12/11/2023 8:43 am
dost thou meanest a standard hugger or the gravel un?
Posted : 12/11/2023 10:07 am
I'm using SKS Veloflex 65 on mine. 2 muddy rides in (and a few not muddy) and all good. Mine use mudguard eyelets but they also do a version with strap on mounts.
https://www.tredz.co.uk/.SKS-Velo-65-Mountain-29-Mudguard-Set-Incl-U-Stays_203822.htm
Posted : 12/11/2023 10:13 am
For mountain biking duties, as above: been running Mudhugger-type (cheapo version, can't remember which brand) for years. This is my old 26" mudguard on the current 29er which doesn't give quite enough coverage so I'll upsize at some point.
Helitape the fork legs if you're precious. I also find a strip of sticky draught excluder tape down both legs makes fitting easier. Something like this:
https://www.ebay.co.uk/itm/385154388169?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=ajrcemizq82&sssrc=4429486&ssuid=fskVY7jvSgK&var=&widget_ver=artemis&media=COPY
Posted : 12/11/2023 10:24 am
IMG_20231112_092214928_HDRPic on a not well cleaned bike. Tyre is WTB Ranger 29x2.25
Posted : 12/11/2023 10:25 am
I used to have a 'The' steerer mounted guard - full moto look. It actually looked horrific, I'll try and find a pic later
Posted : 12/11/2023 10:35 am
Think the Crud XL will be a pretty good solution for you.  Have been using one for around 4 years on a carbon 29er fork without any issues.
Posted : 12/11/2023 10:52 am
old 26″ mudguard on the current 29er which doesn’t give quite enough coverage so I’ll upsize at some point.
I added a 4" flap made of 2 layers of black gaffer tape sandwiching the guard tip then cut to shape, it works well.
Posted : 12/11/2023 11:01 am
Are your forks std length or suspension corrected length (ie big gap between tyre and crown)?
If former then I’m using these on 29x2.6
https://www.sks-germany.com/en/products/bluemels-style-28-75-set-11841/
did shortern the front a little
Posted : 12/11/2023 11:27 am
I just use a Mucky Nutz Face Fender XL with some extra holes cut in it for the attachment ties so that it sits in the right position.
Posted : 12/11/2023 10:10 pm
Is lack of stability for rough terrain the only reason people don't run full length mudguards on rigid forks? SKS 75 has tyre clearance for a 2.6".
Posted : 12/11/2023 10:36 pm
The SKS 75 are very stable, still fine of any off-road suited to rigid riding. Only had the breakaway pop on the fron on larger drops, but since shortened the front been fine since.
Posted : 12/11/2023 11:19 pm
