Front Disck Brake A...
[Closed] Front Disck Brake Adaptor Help?
[#1407501]
Looking for a disc brake adapator for a Hope Mono Mini with IS mount and I want to mount it onto a post mount fork. Rotor size is 180mm. Anyone know where to get one? I looked on here but couldnt see one going from post to IS only the other way around....
http://www.chainreactioncycles.com/SearchResults.aspx?Search=disc+brake+adaptor
Posted : 12/03/2010 9:48 pm
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=13735 ]Hope[/url]
Can't do it and keep the same rotor unless you change the caliper half.
Posted : 12/03/2010 9:54 pm
What size rotor should it be then?
Posted : 15/03/2010 8:36 am
200, if it's an IS Caliper & Post Mount fork, you have to add 20mm to the rotor size to allow for the adaptor
Posted : 15/03/2010 8:38 am
So I cant get an adaptor that will fit a mono mini to a post mount fork with a 180mm disc?
Posted : 15/03/2010 11:05 am
Mono Mini is post mount, so surely you need post to post
Posted : 15/03/2010 11:27 am
THis is IS mount with a no 3 caliper
Posted : 15/03/2010 12:41 pm
If it bolts to on IS fork & uses a 180mm rotor, when you swap it to a PM fork & need an adaptor, you'll need a bigger rotor by 20mm as well. The adaptor spaces the caliper further away from the fork, resulting in the need for a bigger rotor.
Posted : 15/03/2010 8:19 pm
I have a +20mm adaptor for sale, it was on classifieds last week (hope HBSM20H) but as already stated, you're need a 200mm rotor if you are currently running 180mm. It's yours £7.50 posted.
Posted : 15/03/2010 10:05 pm
