Is there any frames that have the same shock length and stroke as a 2014 650b 5?
Shock is 190x50mm??.
I'd rather keep my CCDB CS as it can be tuned to suit..
Interested to see what my options are if I decide to change frames..
I also have 150mm pikes that would need to be used..
You will need the stroke length on the shock rather than the wheel travel to compare. 190 seems a bit shorter than a lot I have had in the past - most of my shocks have been 200/215 ish
Mike
Post edited, believe it's a 190x50mm.
Need to dig out the tftuned invoice to confirm..
Spec camber 29
Clue in the 650b part.. Lol
Must have been cryptically hidden in the "Is there any frames that have the same shock length and stroke as a 2014 650b 5?" Bit 😉
Fair enough...guess I wasn't specific enough.. 🙂
The criptic part is that I have a orange 5 650b, it has 650b wheels to. Not a cobbled together bike with whatever wheels I had spare. Although I think I'd struggle to get 29" wheels in 😀
I want to see what frame options are available for me to swap all the components to a different frame.
[advice you don't want]
Look for a bike you want, try it and see how it goes and sell the CCDB with the orange if the shock doesn't fit.
I'd rather have a bike I like than save a few quid swapping the shock and getting something that doesn't fit or suit me.
Golddigger, i could be interested in the frame with or without shock depending on size. MY email is in my profile if you like 🙂
