Frame breaking - wh...
[Closed] Frame breaking - who's done it?
Nah, not components - we'd be here all week and my memory has its limits...
Posted : 23/02/2011 10:02 am
samurai are you a chubber like clubber?
Posted : 23/02/2011 10:03 am
nope, I'm skinny and fast. And clearly more powerful than the Flying Scotsman.
Or a crap rider.
Posted : 23/02/2011 10:06 am
FWIW Al, I broke most of that stuff when I wasn't a chubber. Though I was also a lot stronger which is probably worse...
Posted : 23/02/2011 10:07 am
I've cracked two Raleigh Dyna-Tech road frames (one chainstay, one downtube by gear-lever bosses)and one Dyna-Tech MTB chainstay. They were utter crap. I worked in a bike shop at the time and most of the frames we sold came back broken at some point.
I had a Klein Rascal that I cracked under the head / downtube join and a Klein Pulse Pro (Trek) that cracked at the seat tube / chainstay junction. (Fair wear and tear on the Pulse though I reckon. It'd had a hard life and lasted well over 10 years.)
Snapped a Raceface Turbine crank arm too.
No pics, I'm afraid.
Posted : 23/02/2011 10:27 am
 LoCo
Specialized epic (shop I was working at's demo bike)
Destroyed as set of Judys over jumping some doubles.
Posted : 23/02/2011 10:33 am
96 gt tequesta (steel) snapped the drive side dropout between the seat stay and chainstay.
It had had 10 years hard use including several as a trials bike and sevaeral as a singlespeed. i had just SS'd as a commuter. did about 30 meters before i turned right and there was a 'very funny feeling' 😯
Posted : 23/02/2011 10:42 am
Cynic-Al and mwleeds the clear front runners at the moment.
Not enough pics in this thread! My only frame breakage was a Grifter when I was 9, I think rust had eaten away at it.
Posted : 23/02/2011 10:47 am
Commuting bike - just commuting along
And a month later I did this:
Airborne Lancaster - just riding along.
Managed this just a week or two ago but the genius bike mechanic I use managed to straighten it back out!
And far more broken bits than I care to remember 🙄
Posted : 23/02/2011 10:51 am
andyl - Member
Verses, looks like you had a crack on the front of that tube emanating from the hole in like with the top tube for a while.
If there was, I'm pretty certain it wasn't visible from the outside as I was fairly fastidious about keeping it clean. It still makes me sad to look at those photos 🙁
I have a mate with the same year's GF Rig which broke in the same place. His warranty replacement had extra bracing there, so clearly something they addressed with newer frames.
Posted : 23/02/2011 10:59 am
1994 Specialized Stumpjumper M2 - just riding along at CyB I thought I had a very loose headset and noticed that the noise was coming from the fact that toptube/seattube weld had failed. Had to ride back on the road holding it all together with 'core upper body strength'!
Contacted SBC and they sent a 2003 Stumpjumper M4 through to my local dealer and picked up the broken frame.
Posted : 23/02/2011 11:07 am
I've broken the cranks of a grand total of five exercise bikes at my local gym...
Posted : 23/02/2011 11:15 am
 cp
What an appropriate timing for this thread, my 2004 commutered inbred just went wobbly this morning!
Aside from that, I cracked two seperate 2000 Gary Fisher Paragon frames at the bottom of the seat tube just above the bottom bracket (well above the weld though). They were very good with warranty replacement on the original, and then a warranty replacement on the warranty replacement!
numerous component failures...
Posted : 23/02/2011 11:24 am
Keep them coming!
Verses - absolutely no chance you would spot that. was in the portion hidden by the top tube. Would have been cracking and fretting away nicely as you pedalled.
Posted : 23/02/2011 11:34 am
CLub Roost XC-4 bent at the headtube and snapped the swingarm riding in BYC.
Kensis Maxlight 04 ish downtube.
Posted : 23/02/2011 11:38 am
Sintesi Bazooka '98 - cracked the swingarm.
Marin Muirwoods '96/'97? - snapped at the headtube doing the Morzine DH tracks.... back in '98 (on a rigid!).
Pitch Pro '08 - cracked 2 chainstays, and frame. All replaced FOC under warranty.
Crank (left hand side) - got the scar on the inside of lower leg where it gouged out a hole!
Posted : 23/02/2011 11:45 am
McMoonter - is your mate on the left a jockey?
Posted : 23/02/2011 11:55 am
I bent a brake lever once and that was about it for breaking stuff. But then I bought a Cotic Hemlock in 2009 and snapped the chainstay where several others have gone. 2010 chainstays now mucho beefy around this area. 9 mile walk back to the car down one of the best descents in the Black Mountains. :cries:
[url= http://farm5.static.flickr.com/4040/4207008206_9c50752f62.jp g" target="_blank">http://farm5.static.flickr.com/4040/4207008206_9c50752f62.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/rick2/4207008206/ ]Long walk back...[/url] by [url= http://www.flickr.com/people/rick2/ ]Rick T.[/url], on Flickr
[url= http://farm3.static.flickr.com/2619/4207008902_07d565303d.jp g" target="_blank">http://farm3.static.flickr.com/2619/4207008902_07d565303d.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/rick2/4207008902/ ]Chainstay snap![/url] by [url= http://www.flickr.com/people/rick2/ ]Rick T.[/url], on Flickr
Posted : 23/02/2011 12:02 pm
Bent the forks back and rippled the frame on my Mont Cenis road bike back in the late 80's. Was racing some mates (on their BMXs) down an off road trail. They had grip + I didn't = crashed into fencing on a bend.
03 Enduro S Works - broke the frame in about 2005. Can't remember how or where it happened.
04 Enduro S Works - broke the ream arms in 2008. Trails on Ranmore.
07 Stumpy Carbon - broke the frame last year. Road session - very random snappage.
Have also broken seatposts and bent brake levers etc.
Posted : 23/02/2011 12:11 pm
Two Marin Attack frames cracked around the main pivot. Bit of a weakness with these frames but replaced with no quibbles.
1997 Orange Gringo hardtail - snapped at the top of the seatstay. Had been riding it for about 8 years so can't really complain.
Posted : 23/02/2011 12:24 pm
My Cannondale gemini,Snapped the Rear swingarm.Replaced under warranty
Posted : 23/02/2011 12:28 pm
Saracen X-ESS, Snapped the chainstay and bottom bracket.
Azonic DS-1, Took headtube off
Azonic DS-1, Twisted the frame (head and seat tube out by 5 degrees
Santa Cruz super 8. Snapped pivots
Santa Cruz Super 8. Snapped the rear end brace.
Giant AC Team. Took seat tube off
With parts, i have snapped to many. just say most things.
then had some time of the bike and in 3 years nothing yet.
Posted : 23/02/2011 12:41 pm
Posted : 23/02/2011 12:43 pm
 jhw
2002 Specialized Enduro - first I killed the linkage. Bought a new linkage (it was a second hand bike). Then a few years later an upflying rock at CyB dented the BB shell, I took it for a few more rides but the dent became a crack so I had to scuttle it.
Query whether an upflying rock is fair wear and tear on a mountain bike. There is an argument that mountain bikes should be tough enough to withstand that kind of impact. The bike came with a frame protector on the downtube but it didn't cover the most vulnerable part, the BB area. I've fashioned such a protector on my new Enduro. My shop lampooned me for it, "these bikes can take it", etc., but I know otherwise.
2006 Specialized Roubaix - the glue failed in the BB shell (connecting the shell to the carbon frame, I understand) so the BB shell cracked
I never asked Specialized about replacing the Enduro because it was second hand so why even bother? They were great about replacing the Roubaix.
Posted : 23/02/2011 12:47 pm
i wondered how long it would be before a 2009 hemlock chainstay reared it's head.
you can fix it with an inner tube...
Posted : 23/02/2011 12:57 pm
My first Enduro was second hand. When it (the frame) snapped, I called them up and told them it was second hand > they said bring it in > which I did > they offered me the 04 S Works with new shock for £400 under CRW.
Can't say fairer than that. Top folk are Spesh.
Posted : 23/02/2011 1:00 pm
Mid 90's Dawes 631 Edge, snapped at rear dropout while going over fallen tree on some singletrack.
Cheap Russian Built Coyote Ti frame, cracked at seat stay/top tube joint.
Then more recently cracked a Tomac Eli at Transwales, though never found cracks until home that was after ripping the splines off an XT crank 2 miles from the end of the last stage.
Finally snapped my Karate Monkey on the BB end of the BB at Dusk til Dawn.
Posted : 23/02/2011 1:18 pm
 gazc
no pics but:
ribble reynolds steel road frame - snapped the top tube cranking up a hill
stab primo 2002 - cracked the shock mount
stab primo 2003 (replacement) - bent the down tube after a stack on a rock garden
brand x xc frame circa 2003 - cracked seat tube/seat stay weld and not much use either
Posted : 23/02/2011 1:31 pm
Broke my Hemlock in the place where old Hemlock chainstays break. No warranty, I bought it used, Cotic replaced the chainstays for free in 2 days anyway with the new model which was pretty fantastic of them.
Oh and I broke my raleigh budgie in half at the top/downtube (it only had the one tube) by riding it into a river.
Posted : 23/02/2011 2:26 pm
Hairline weld fracture on my Titus Racer X at the seattube top tube junction. I blame the fact i was running a seatpost shim so it was pretty much running at minimum insertion at all times.
I miss it 🙁
Posted : 23/02/2011 2:48 pm
 Tim
Samuri and Matt (if he's still on here) must be the winners 🙂
Posted : 23/02/2011 2:53 pm
Snapped the rear seat stay of a Klein attitude because I'm an idiot*
Wish I still had that frame.
*Jumping
Posted : 23/02/2011 2:59 pm
Cove Hustler mk 1 broke at top tube/ seat tube weld. New mk 2 full frame suplied as warranty replacement.
Posted : 23/02/2011 3:01 pm
 5lab
put cracks in the front triangle of 3 transition prestons - one was 4 years old (so fair enough) - the other two were under 10 hours of riding each. Its fair to say that I no longer buy transitions (although they did change their front triangle design)
Posted : 23/02/2011 3:05 pm
i recently broke a carbon '09 spesh epic - a v v small crack appeared near the bb chainstay area. so small i thought it was paint flaking off - spesh warranty took one look at it and replaced the frame with a nice sparkly new one.
Posted : 23/02/2011 4:17 pm
Snapped forks on a Grifter and snapped an Ultra Burner frame in half but that was a long time ago now and I would put that down to the quality of the Hi Ten steel.
I must be a light rider compared to the rest of you.
After reading Singletrack issue 2 I wouldn't bet on many IBIS Ripleys still doing the rounds.
Posted : 23/02/2011 4:47 pm
Snapped the drop outs off an early Heckler
Ellsworth Isis broken frame at seat tube and around mainframe shock mounts
Ellsworth Joker swingarm
and then the Joker/Isis frame parts hybrid on Sunday last at the BB weld.
I'm hoping the next purchase lasts a bit better.
Posted : 23/02/2011 6:00 pm
Titanium frame cracked across the seatpost/top tube weld
sorry bout the colour, its the only way the crack shows in the pic; see!
Specialized SX trail cracked going off the large ladder multiple times at Chicksands, luckily held together whilst I was riding, only noticed it the next day at home
Lastly this one's not mine but an expensive mechanical to one of the group in Les Arcs July 2010. Double discs not secured correctly to the frame, apply brakes, brake retaining bolt cracks and wrenches apart the rear triangle of a brand new Nicolai
Posted : 23/02/2011 7:04 pm
Andy
Posted : 24/02/2011 11:02 am
 cb
[url= http://farm6.static.flickr.com/5053/5473595478_278c5be774.jp g" target="_blank">http://farm6.static.flickr.com/5053/5473595478_278c5be774.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58244036@N02/5473595478/ ]0704liquidcrack 015[/url] by [url= http://www.flickr.com/people/58244036@N02/ ]craigbart[/url], on Flickr
Think these had a bit of a reputation for this. Have to say Trek were spot on with the replacement.
Posted : 24/02/2011 11:35 am
The usual suspects keep croping up above...
Posted : 24/02/2011 8:32 pm
Raleigh Maverick - cracked at the rear drop out.
Orange Prestige - cracked at the rear drop out.
Santa Cruz Heckler - broke clean through on the seat tube / bottom pivot weld.
Another Santa Cruz Heckler - same place.
Scott Single pivot full susser - cracked swing arm. One morning ride - oops!
Turner 5 Spot - clean through at the taco weld on the seat tube.
Cove Hummer - cracked at one of the gussets.
Ritchey Cross Bike - bent by an ejit in a car deliberately running into me.
Not broken my DW 5 Spot ....... Yet!
Mb
The
Posted : 24/02/2011 8:48 pm
Sanny - Member
Hecklers hav one pivot which is on the downtube.
I smell a rat!
Posted : 24/02/2011 9:00 pm
Mid nighties Orange Clockwork (C-16) .Was racing xc at Cheddar when taking a bottle from downtube and it felt loose. so thought bolts had worked loose, wrong the bolt mounts had pulled away from downtube in a thin strip. Replaced no problems.
Posted : 24/02/2011 10:39 pm
Snapped a Whyte PRST-1 when the bridging plate connecting the brake caliper to the fork failed and put the caliper into the wheel, snapping the fork clean off just above the brake mount on the left side and up by the linkage on the right hand side. Was "just riding along", down a single track road when a wee tipper lorry was coming the other way, i braked, the bike broke and i faceplanted in spectacular fashion right in front of him. Fair play, we put the bike on the back and he took me home. It was only 18 months old at the time and ATB Sales were only going to replace the fork but the lads at J E James in Sheffield basically said "you wanna see the state of this guys face, i think maybe some kind of goodwill gesture would be appropriate". Few weeks later i recieved a PRST-4 frame which 8 nearly years on is still going. Definitely would have liked to have seen an action replay of it all going tits, would have been quite entertaining.
Posted : 24/02/2011 11:05 pm
Page 2 / 3
