Frame bag for HT
[Closed] Frame bag for HT
[#11447585]
Looking for a small frame bag to sit in the headtube/down tube/top tube junction.
I like the look of the Cotic x restrap ones (for S,M longshot bikes). So a relatively compact one. I don’t own a Cotic. Before I get on to them and purchase, does the Stw collective have any alternatives? Other than going custom? It’s for a newish medium P7.
TIA 👍
Posted : 26/10/2020 12:56 pm
Well I can only recommend Wildcat Gear. Custom or OTP.
Posted : 26/10/2020 1:07 pm
Also interested, although probably for a bag that goes under the top tube and in front of the seat tube.
Posted : 26/10/2020 1:16 pm
I’ve been mulling over same. Evoc do a bag similar I’ve been thinking about, not sure sizing however.
Posted : 26/10/2020 3:58 pm
I have a Blackburn Outpost corner bag, I use it on my Bird Aeris as it's not got much room but should work fine on a hardtail as a small bag. On my hardtail I run a bigger Podsacs one that is between top and seattube.
Posted : 26/10/2020 4:19 pm
£7 odd at OnOne a couple of months back.
Posted : 26/10/2020 4:21 pm
A bit bigger, but I've got a medium 'normal' (not Cotic) Restrap one on my medium frame Switch9er.. fits well and stays put.
Posted : 26/10/2020 4:25 pm
@matt_outandabout ... Yeah, that's exactly what I want, saw those on PX, and didn't get one. Now they're no longer available 🤦
Trouble with the ones that fit up behind the headtube is that it makes it difficult to use the bottle cage on the downtube ... Fine for the gravel bike which has a cage on the seattube, but both my MTBs only have one cage, on the downtube.
Posted : 26/10/2020 4:50 pm
Vaude?
https://www.wiggle.co.uk/vaude-cruiser-frame-bag
Posted : 26/10/2020 5:02 pm
Cheers All.
May give the Cotic one a try. It’s exactly the size/shape I want. Love something custom but £100 ish is a bit hard to swallow!
Posted : 26/10/2020 10:28 pm
Ive been using this one from decathlon fir a couple of years now. Less than a tenner. https://www.decathlon.co.uk/p/300-1-5l-bike-frame-bag/_/R-p-120030
Shown on a medium mk2 Solaris.
[url= https://i.postimg.cc/vZ25nMJY/20190422-144938.jp g" target="_blank">https://i.postimg.cc/vZ25nMJY/20190422-144938.jp g"/> [/img][/url]
Posted : 26/10/2020 11:01 pm
I've got a Cotic one on a large frame. Works nicely. When I get my Stanton frame if it fits i might rebadge it 🙂
A mate has the Evoc one. Looks really good and about the same size i'd say.
Posted : 26/10/2020 11:27 pm
I've got this Alpkit bag on my Bird Zero TR. A Lezyne Mini Track Pump sits just nicely in main compartment with room to spare for multitools, keys, other stuff. Mobile goes in slim compartment other side (though might recommend additional protection for it, especially if bag is fairly full).
Posted : 27/10/2020 12:42 am
@sirromj, does it have enough space for an extra saddle?
Posted : 27/10/2020 1:35 am
I had a Restrap one and although I used it for a while and it worked well enough, I never really got on with it. For some reason, it always felt awkward to use. For example, although it has pockets on both sides, as soon as you put something in one side, the other side becomes almost unusable.
I replaced it with an Apidura one which seems to work much better - not much bigger on the outside, but I can always fit more stuff in if I need to, and the pocket arrangement works better, with more attention to detail, like the provision of a hole for a charger cable, zips that are easier to handle with frozen fingers, more waterproof, a little zip section for phone/cards, etc.
Posted : 27/10/2020 8:56 am
Try weecog custom bags, I paid £50ish for a small bag (though it was very large small bag to fit a geomatron). Get some cardboard out to make a stencil for what you’re after and take measurements.
Posted : 27/10/2020 9:26 am
I’ll second Weecog.
They’re a pleasure to work with. Measure up your frame and let them know what you want and within a couple of weeks you have a custom bag. You get to choose the colour too. The quality is also great.
Posted : 27/10/2020 10:36 am
Beer Babe makes a 'triangle pack' that looks as though it might be what you're after and at £17 cheaper than a lot. I've not bought from her but she gets very good reviews and will do custom bags. Handmade in the Uk too.
https://www.beerbabe.co.uk/ourshop/prod_6599570-Triangle-Pack-Rear.html
Posted : 27/10/2020 11:47 am
